Upgrading stereo unit to sat nav
Highlander1981 Nov 17, 2011
  1. Highlander1981
    Highlander1981 New Member
    Hi all, please help!
    I have a 2010 a3 with a chorus stereo unit which has bluetooth and I pod lead with the info linked into the DIS. I want to change the stereo for a sat nav unit, whilst keeping the iPod and Bluetooth, how easy is this to do? Will I only need the sat nav unit and the others will connect into it?
    Thanks!
  2. audigex
    audigex Active Member
    600
    46
    If you use the RNS-e I believe you can keep the bluetooth but that you'd need to get the AMI connectors to go with the RNS-e, you can't use the current iPod cables etc.
    Don't take that as gospel, though.
  3. BBlackburn
    BBlackburn Member
    395
    9
    And if you get an rns-e will need coding to suit what you have installed with it for it to function properly and no fault codes to be thrown up.
