Upgraded Brake Discs For 2.0TDI A3
Lance-22 Dec 26, 2008
  1. Lee_R
    Lee_R Active Member
    2,499
    12
    Did you get a price for the carriers?
    Mine will be needing discs and pads in the next few months so it would be rude not to upgrade them!:thumbsup:
  2. kaz219
    kaz219 Active Member
    1,808
    The A3 3.2 V6, S3, R32 MK5, LCR MK2 all have 345mm discs - They're all the same but in diff colours and the S3 has the S3 plague at the front and aesthically a bit diff.
    But to upgrade to the 312mm (Same as the Golf GTI) - as above - just need the carriers and discs.
  3. A_C4mby
    A_C4mby Member
    51
    :anbet: I'm a novice!!!!!
  4. Lance-22
    Lance-22 A3TDI
    im still struggling to find out the standard rear disc size on a 2.0tdi 140??
  5. mhill
    mhill Member
    323
    would a MY09 2.0T S Line have 312's?
    Devonboy, another face from SCN!!
  6. Lance-22
    Lance-22 A3TDI
    i have finally found the information i was looking for so thought i would post it on here for others:
    2.0 TDi 140PS....
    Std fronts are 288 x 25
    Std rears are 255 x 10
  7. ~RS~
    ~RS~ Active Member
    1,466
    22
    Did you find any vented drilled disks? I need a set of disks and pads up front and was also after the aesthetic value... My current wheels show alot of the disk and my new ones will be even worse! £££ Is not available for the 312/345mm conversion, will get some good pads.
    Where do I find the drilled vented disks? And how much?
  8. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    My front brakes where 312mm same as the golf GTI stuff.
