Upgrade BNS 5.0 / RNS-Low with RNS-E
markhaines Jan 29, 2012
  1. markhaines
    markhaines New Member
    12
    Hi, I've been considering upgrading the BNS 5.0 head unit in my Audi A4 B7 with an RNS-E unit. The current system has a 6Disk CD Multichanger in the glove and factory fit bluetooth handsfree as well as a phone prep in the armrest.
    I was wondering whether:-
    - Is the Bluetooth built into the BNS unit or is it an extra module? Is this plug & play with the RNS-E if so?
    - Are the multichanger & GPS aerial also plug and play with the RNS-E?
    - Once i've upgraded the unit is it simply a matter of using VCDS to configure it? I've got a generic cable and the $99 version of VCDS which can currently 'see' the BNS unit. Will this be good enough to finish the job off?
    Any help much appreciated.
    Mark
  2. s8craig
    1,746
    53
    Bluetooth is a seperate unit, so no changes required there between BNS and RNS-E
    No it's not plug and play, the K-line wire will have to be moved along with the BOSE wire, but I don't think you have BOSE.
    Yes everything else will work as before.
    You may get away with a cheapo VCDS cable if it allows coding over K-line
  3. Amason007
    Amason007 Member
    116
    41
  4. markhaines
    12
    Thanks for the replies. I do have Bose, forgot to mention this. I'll read round moving the wires.
    Thanks!
