Up down window fault
SOULdOUT Jun 29, 2006
  1. SOULdOUT
    SOULdOUT New Member
    '98 Audi A6 1.8t Saloon, both front electric windows have been playing up..
    Depress button for window to go down.. drops.
    Pull up and it shows an inch or so then dissappears back in door, pull it up again and u might get 6 inches.. then it goes back down again..
    only way to get it shut is to hold it pull it and be gentle..
    WHY?? and how to fix it..???
  2. Jason
    Jason Member
    188
    Window comes up then stops and returns back down again because of friction resistance in the runners/guides, which in turn kicks in the child safety (anti squashed finger) and opens window again!
    Try blasting a silicon based lubricant into the felt runners (failing that WD) that the window slides up and down in.
  3. MartinM
    MartinM DK55 XYH
    had the same problem on both my A6 and the Seat Leon i had before it, best thing to do is have the regulators replaced.
    www.4ringspares.co.uk is a good place to start
    HTH
  4. simonwjones
    simonwjones Member
    365
  5. HNH5
    HNH5 Member
    42
    Mine does exactly the same (A6 98 1.8T) - i've now just disconnected the drivers window from the button unit and haven't bothered fixing it yet. Very interested to see how you fix yours though.
  6. HNH5
    HNH5 Member
    42
    Any update on getting your window fixed?
  7. marmite
    marmite Counting the Tesco Club points
    1,101
    Sounds like regulater are broken, not a bad job
    pop the door trim off and have a look to see if the green plastic clips are broken, there is sometimes bits in the bottom of the door.
    If they need replacing you need to take the whole door frame out and rerivot the new one on 1.5 a side roughly by the time you readjust door frame
    BTW loving the wheels
  8. Kevshann
    Kevshann New Member
    Had this on A6, S6 and RS6. It's damn annoying and in my opinion is a design fault. It's usually cured temporarily by lubricating the channels, but over a time stresses the regulators and they need replacing and guess what.... before too long it all happens again.
