Unplugging maf sensor plug
Newbos Jan 20, 2013
  1. Newbos
    Newbos Member
    115
    Guys
    Should the engine management light come on if I unplug the above?
  2. Custardsucker
    Custardsucker Member
    112
    Yes should do. Mine came on after turning ignition off & on, also I think ESP light came on. Presume they're both fed from same supply.
  3. Newbos
    Newbos Member
    115
    It doesn't matter it's a diesel does it? Should come on whether it's a diesel or a petrol?
  4. <tuffty/>
    21,560
    4,044
    ESP light will come on to indicate that the ESP system is switched off... the ECU is a load based ECU which requires input from the MAF... the ESP controls engine torque which is derived from load... if the ECU is blind to load then the ESP can't control torque and is deactivated... a MAF open circuit fault code will also be logged..
