Unlock button on fob does not work- Lock and boot pop do work
Kieronboz May 6, 2014
  1. Kieronboz
    Kieronboz Member
    99
    Hey guys, I only have 1 key for my car so i havent been able to do the resync where you leave one key in ignition then use the other- etc, but i tried the putting key in door handle and using buttons on fob then, and nothing happened either.
    Is this likely a problem with my key or the button or something?
    Have searched but all topics seem to be about 100% failure of the key which makes me think mine may be isolated to the unlock button only.
  2. hollow
    hollow Well-Known Member
    1,404
    162
    sounds like it needs a new micro switch in the fob
  3. NHN
    29,328
    1,708
    Only definitive way to know, is to check with vcds to see if its actually seeing the signals from both keys, ideally clear out all keys & resync the 2 again.
  4. Rennie_thegiant
    Rennie_thegiant New Member
    Had this problem myself last week thought the button was broken. All I did was remove the battery quick dust and blow around the battery housing then put the battery back in and not had a problem since.
  5. Big Pumpa
    Big Pumpa Member
    135
    Exactly the same works for me every time too
