uneven idle
hubbo1 Jun 1, 2012
  1. hubbo1
    hubbo1 Member
    118
    hi i have an a4 tdi s line auto 2005,it has a very slight uneven idle,i have cleaned the egr valve and air intake,just wondered if there is anything else i can try?
  2. gary3306
    gary3306 Active Member
    989
    41
    When you say uneven idle, do you mean the engine doesn't tick over smoothly or there is a bit of a vibration that sort of comes and goes?
    Reason I ask is if its the latter, you may be in the early stages of DMF failure. If its vibrating slightly at idle, try dipping the clutch as its in mid vibration, and see if it improves slightly. If it is the DMF I hope you have a large wallet or an understanding bank manager.
  3. hubbo1
    hubbo1 Member
    118
    thanks-but as its an auto id be suprised if it had a dmf! lol
  4. gary3306
    989
    41
    Hmm, i must learn to read posts properly. Yes, you're right, ignore my post.
  5. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    Mine has.
    Try changing the fuel filter and have a good look for air leaks in the inlet hoses.
    One tip is to spray the hoses one at at a time with wd40 while the engine is running, if the idle goes up you have a leak on that hose.
