Uneven and odd idling.
Eddie Mar 8, 2009
  1. Eddie
    Eddie Member
    39
    Hi I have a question my car have a very uneven idling and the car makes vibrations on idling, the idling moves from 500-700rpm. I found that this problem was pretty ordinary on audi A3. So I just wonder how I should solve this.
    I am buying some new sparking plug and will change the oil. But what more could I do to get rid of the problem. (Change LMM?)
    I have a Audi A3 2.0FSI -2004. And when I check whit VAGCOM there is two codes on the engine that worrys me.
    2 Faults Found:
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 008 - Implausible Signal - Intermittent
    18322 - Pressure Sensor for Brake Boost (G294):Implausible Signal
    P1914 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    What could that be? The EVAP most have something to do whit LMM but the pressure sensor for brake boost does that have any thing to do whit my odd idling? Appreciate every help I could get Thx
  2. L3e123
    L3e123 New Member
    I to would like to know if there is anything that can solve this problem as i have exactly the same car (2.0 fsi on a 04 plate) but i do not have vag com so do not know if the occurring faults are the same. was considering changing coilpacks as well as spark plugs as i know these can sometimes cause problems.
  3. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I too have this Problem my dad said it could be the spark plugs misfiring...and that I need to change them....
  4. Eddie
    Eddie Member
    39
    Yes I am sure that the sparking plugs whold make it little better but I dont think thats the major problem, I know that the LMM is a well-known part that often break down in audi. But if any one have experiance of fixing this pls share whit us..
  5. Morzy
    Morzy Member
    42
    I'm having the same problem, 04 plate 2.0 FSI
    Must be a very common fault on these cars for us all to share the same thing!!
    Mine also struggles to start if its only been stopped for a short time i.e. filling tank with fuel? anybody else have this problem also?
  6. Eddie
    Eddie Member
    39
    What about crank shaft sensor does anyone know what function that one has? Someone told me that it could be the crank shaft sensor but I dont even know where that is located in the engine room. :detective2:
    L3e123, digzz and Morzy - if anyone of you could do a VAGCOM check on your cars we could exclude one of my fault codes, that should make it easyer to solve the problem..
  7. Morzy
    Morzy Member
    42
    I had mine hooked up to Audi's Diagnostic machine and the 2 faults that came up were the temp sensor and the crank angle sensor.
    I swapped the temp sensor as the tech thought that becuase the car was turning over and not starting it might have thrown the crank angle sensor out.
    When the temp sensor was changed both faults cleared, but now i'm thinking that i should have changed this at the same time?
    N.B the crank angle sensor is located on the front of the block on the left hand side.
  8. Eddie
    Eddie Member
    39
    okej thats nice but did the uneven idling go away? or just the problem you had whit starting the car, let me know if you change the crank angle sensor (is that the same as crank shaft sensor?)
  9. Morzy
    Morzy Member
    42
    No uneven idling is still there....
  10. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Air leaks - look for split pipes/holes/perished seals...
  11. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    I second this - had a slight inconsistency in my idle, and found that the dealer had undone the bolts on my aftermarket DV and not tightened them properly after it went in for its 20k service (and worse besides).
    Once it was re-tightened it was back to normal, but I had a sense there was an air leak as I could hear a high pitched whistle. They can be hard to find, but check all your hoses top and bottom to make sure they have no breaks / cuts. Also check to ensure your airbox is properly closed / screwed back together, 'someone' (!) had not closed mine down properly on one side and had trapped part of the air filter material in the lip edge (so I have effectively now had to perform a 2nd after-service!!!)
    PLEASE also note, overtightening jubilee clips can cause the rubber hoses to sever causing air leaks so be very careful how you tighten things.
  12. J.R.
    1,405
    68
    Did any one else solve this problem? :uhm:
  13. pdv40
    pdv40 Member
    187
    I have the same problem on a 2.0 TDi, Audi are changing the clutch and flywheel under warranty next week, I'll update you later if it makes any difference...
  14. pdv40
    pdv40 Member
    187
    Had the clutch and flywheel changed and so far the issue hasn't recurred...
  15. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    I had my revs going up and down loss of power etc... It turned out a split air pipe and the breather valve was knackered Audi replace them both its fine now.....
  16. FL1X
    FL1X Member
    61
    As mentioned above change the breather valve and piping it's a very common fault with all petrol cars ive known them as pcv valves in the past little bit of plastic with a metal ball in it.
    Changing the coil pack I would do as a last resort as they are a bit pricy
    Check the air box for oil if there is oil pooling get it down the garge and get a pressure test done
    Hope that helps
    F
