Underfueling and noise from the fuel pump
spiker May 23, 2010
  1. spiker
    spiker usually growling at something
    200
    Hi
    engine management light on - Vag com reports underfueling and whine from fuel pump intermittently
    Fuel pump changed - noise still there
    Maff changed
    Thermostat and temp sensor changed
    Fuel filter replaced
    Still no better
    Dis reports 42mpg overall !! which is inaccurate - checked based on last fuel load and was actually getting 29mpg
    This has been going on for 6 months now and I know i should just take it to audi ( my local garage is not very s3 friendly ) but i am trying to avoid the dreaded dealer rate
    Any suggestions much appreciated
  2. Andrew@A.L.D
    3,879
    617
  3. spiker
    200
    How is that done ?
  4. Andrew@A.L.D
    3,879
    617
    some of your local fuel injection specialists should be able to help
  5. <tuffty/>
    21,969
    4,247
    Could possible be a problem with the fuel pressure regulator (FPR), check the vacuum hose coming off the FPR which is on the right hand side of the injector fuel rail.
    Could do with being logged tbh, You are not too far away from Badger 5 (J13 M5)... might be worth giving Bill a call, he would be a lot cheaper than a dealer :)
  6. sportstractor
    sportstractor Chugger
    2,709
    was also going to suggest fuel pressure regulator.
    Ha my local Audi garage dont seem to be S3 friendly either, they seem fearful of the thing
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Thats because, IMHO, Audi Mechanics know as much, or less than, your average work a day mechanic.
    They are the same old bodgers in nice overalls.
  8. Welly
    10,696
    130
    Agree. Does the fuel pump still whine, even though it's been replaced?
    The FPR being shot would explain the whine of sorts - it is probably being over worked due to fluctuating pressure requirements.
  9. spiker
    200
    Cheers guys - FPR next then
    Do you have any contact details for this 'badger' ?
  10. sportstractor
    2,709
    its badgerbill on this forum
  11. <tuffty/>
    21,969
    4,247
  12. spiker
    200
    The Badger discovered a knackered FPR , replaced the top lambda , fuel filter and blew out the pipes
    Strange black residue coated the FPR - which turned powdery when dry - no idea how it i got in there or what it was
    So all sorted -
  13. Welly
    10,696
    130
    Glad it's sorted, I saw it up there and thought she may have a knackered FPR.
    Could be residue from contaminated fuel - there was a big thing a long while back where Tesco sent a batch of fuel out contaminated with Silicone and it shagged a ton of Lambda sensors.
    Could be something similar - I've had dodgy fuel before (normally always from Texaco - AVOID!), when emergency filling with sh**ty fuel.
  14. spiker
    200
    I try and avoid supermarket fuel , on the odd occasion i use if i have no choice but usually just to get me to shell
    I remember those issues a while back - shame there's nothing I can do about it
