Uncleared fault codes
vwgtiking Feb 8, 2014
  1. vwgtiking
    vwgtiking Active Member
    1,029
    If you rectify the problem picked up from vcds but do not clear the code. Will the car still run as if the problem is still present until the code is cleared?
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    depends on the problem...
    Is some cases, the ECU will go to normal operation if the faulty device/sensor/condition has been resolved. The fault code remains to let the technician know what was happening. If the MIL indicator is on, it may remain on until the code is cleared.
    There are other cases where the code has to be cleared to reset learned values and get things back on target.
    Now that we talked in generalities, care to share some specifics?
  3. myke
    myke Member VCDS Map User
    95
    It does depend on the fault but normally the car will run as if the fault was not there.
