Unable to access RNS-E via VCDS
Steve77 Apr 24, 2014
  1. Steve77
    Steve77 Member
    70
    Hey guys, I yesterday swapped out my old BNS 5.0 for a Mk2 RNS-E.
    Obviously beforehand I trawled this forum and the net to ensure I had everything I needed.
    Luckily as I already had a Nav unit my car has accepted the RNS-E straight away and everything works fine.
    But i thought I'd check VCDS to make sure it was all setup ok.
    Problem is if I click on the Navigation or Radio module it gets no response and times out.
    As per the guides I have found I moved the Green/Blue K-Line wire to the B5 space.
    Am I missing something else......?
    Steve
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Not 100% sure that you have to move the K-line when you do the BNS to RNS-E swap, you definitely need to do it when you do the Symphony II+ to RNS-E swap though.
  3. tommytonguedj
    tommytonguedj Member
    133
  4. Steve77
    Steve77 Member
    70
