*UK'S FASTEST S3** 450+BHP REVO STAGE 3+* FORGED ENGINE* RS4 BRAKES (2007)
Kelza May 10, 2012
  1. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
  2. Kelvin_S
    Kelvin_S Member
    243
    Wow that's insane, I wonder why he is selling though...? With that amount of power it can't be too reliable
  3. Kelza
    3,078
    605
    You would probally need to strip the botton end down and get the turbo checked...
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    More like worrying it's that cheap!
  5. Kelvin_S
    Kelvin_S Member
    243
    Lol yeah I bet you something big is about to go pop. Unless your a mechanic, I would stay well away. Great car though.
  6. AudiAndy21
    AudiAndy21 Member
    176
    and it looks like its been in a fight with a kurb... and the kurb won.. distroying two of the wheels.. and damaging the rs4 brakes.. untold damage to the suspension and other components?
  7. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    it was. this was andys car he used to be a member on here!
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    one its not the uks fastest by a long shot, and two if i recall andys engine blew up due to going ott on the water meth
  9. S3Alex
    10,804
    4,805
    Absolutely right.....he'd been caning it chasing an R8 V10,and shortly after,lunched a piston,having been running all of that on stock internals.
    If you build the engine right in the first place,it can be perfectly reliable.....mine had run over 440bhp without a hiccup for 10 000+ miles,before adding another 60 or more bhp with forged internals...still perfectly reliable,and if you ask a number of us all running over 500bhp on this engine,we'd tell you the same.
  10. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    One of the times it's certainly NOT better to buy modified. I don't really see why people are wary buying a car with an exhaust and a map, but this much work needs a lot of very careful checks before any parts with money. It'd be amazing to get my car up to 450bhp, but I'd always rather know exactly what was done when, and who did it. At that price, you can only imagine it's got a massive bill just round the corner so we want to sell it on to someone who wants to keep it going.
  11. S3Alex
    10,804
    4,805
    Exactly.....this car we all know had been caned to put it mildly,and has clearly also had an engine rebuild since that time,following the piston failure.
    I know exactly who built mine,what parts were used,and have all of the bills,plus even the names of the engineers who worked on it,and whilst I am not saying the seller of this couldn't do the same,what I am saying is that a build of this sort needs to be done properly,and the car then needs to be looked after properly,and only if you do those 2 things well,will you get a reliable car.
    Also.....fastest S3 in the UK.....probably not any more,as there are a few significantly more powerful ones around.
  12. akash_sky1
    akash_sky1 Active Member
    1,181
    Shame it's not actually the fastest S3 in the UK and has blown an engine!
  13. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    What about Dans S3, JonnyC`s old one?
  14. S3Alex
    10,804
    4,805
    Dan is busy dismantling it and returning it to stock,as he has other plans right now.
  15. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Interesting, even the `special` gear gearstick?
    Almost seems a shame to return a 500+bhp S3 to stock, although I guess economics rule.
    Im sure the trick bits will be snapped up.
  16. S3Alex
    10,804
    4,805
    Last time I spoke to Dan he had another project in mind.
  17. Kelza
    3,078
    605
    Hi alex do u think its worth while doing all the poly bushes?
  18. S3Alex
    10,804
    4,805
    Only after you've done all the other bits.
  19. Kelza
    3,078
    605
    Hi alex cool getting my car all ready ,so stage 3 would be the next big step , may do engine internals before bt etc, is there any thing that can be done to stengthen gear box?
  20. S3Alex
    10,804
    4,805
    Not a whole lot....you can get the bearings done as mine have been,but there aren't any uprated gear sets for the S3.
  21. Kelza
    3,078
    605
    Gearbox out to do the bearings?
  22. S3Alex
    10,804
    4,805
    Absolutely!
  23. Kelza
    3,078
    605
    Cool thanks :)
  24. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Can you not put diesel gears in the box like we do with Golf R32`s ?
  25. S3Alex
    10,804
    4,805
    I only took the advice from the guys who rebuilt the box......that's a good point though so I may ask when I get some time.
    Thanks!
  26. S3Alex
    10,804
    4,805
    Had a think about it over the weekend.
    When mine was rebuilt,it was the selector forks and a few of the bearings that needed replacing,but the gears were OK.
    Also,the transfer box was toast.
  27. devonmikeyboy
    1,245
    It`s fourth gear R32`s tend to strip in the standard 02M box when going turbo so most people fit diesel gears as they are stronger and much longer so you then have a useful 1st gear and higher top speed. The gears are much weaker then the transfer box which even the 1000 bhp r32`s don`t break the gears as it`s the cases that get rip in two. I have several transfer boxes if you ever need one again.
    Steel uprated shifter forks Steel Shift Fork Transmission Upgrade / 6 Speed (02M / 02Q) - USP1190
  28. Kelza
    3,078
    605
    Interesting that ,good one, i used to have a diesel gear box in my rs turbo ,as you could rev it to red line all day long :)
  29. S3Alex
    10,804
    4,805
    Mikey,
    You're a star...I hope not to need any transmission parts again,but if I do,I know where to go.
    I am reasonably sure the problems with were there from new as the box always whined a bit and coming from a straight cut box on the Escort I didn't really think about it too much.
    When it was stripped down there was a considerable amount of brass filings around in the box.
