Uh oh...problem with my new S4......
S4_dan Apr 20, 2006
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,713
    162
    Ran vag-com today and it came up with 3 faults....I'm hoping all 3 faults are stemmed from the very first fault....here goes......
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 551 C
    Component: 2.7l V6/5VT 0002
    Coding: 05611
    Shop #: WSC 00216
    3 Faults Found:
    17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
    P1454 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
    P1462 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Can anyone tell how many Exhaust gas Temp Sensors my S4 will have? one or two?
    What sort of price and are they easy to change?
    could fault 1, cause faults 2 & 3 to occur??
    Cheers for any advice.
    Dan
  2. Broken Byzan
    13,237
    465
    the middle one is from a low battery, probably from where its been stood, the others may be related, i am afraid they are beyond my scope of knowledge
  3. The911SC
    The911SC Active Member
    1,032
    I would just clear them and then re check. Sometimes the spurious errors can be related.
  4. dummi
    dummi smoking a6
    1,210
    FYI there are two EGT sensors one on each of the turbos exhaust housing, apparently they are like the o2 sensors in that they go frequently. they're about £80 each from vagparts. but do do as The911SC and check again first you might be lucky with them
  5. doeboy
    doeboy Member
    602
    Can someone explain to me what VAG-com is and how to run it please?
    Pm me if needbe.
  6. AndyMac
    9,832
    45
    VAGCOM is the software you need on laptop or similar in order to interrogate and/or change the settings in the ECU for all VAG group vehicles
  7. doeboy
    doeboy Member
    602
    Right so something you end up paying for at your local audi or german garages then! hm....
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,337
    2,879
    [ QUOTE ]
    [/ QUOTE ]
    Not necessarily. There is an entire forum on ASN, dedicated to VAG.com.
    Here: VAG.COM
