U.K 2010 S5 Convertible Rear Led VCDS Coding
rookie Aug 25, 2017
  1. rookie
    rookie Member
    75
    14
    Hi all,
    As you may or not be aware I just had my comfort control module changed after my previous one failed. I got the car back yesterday and all appeared well. However when I locked the car today I noticed the amber rear indicators did not flash, instead it was a red light that illuminated (on the outer cluster inside the led section). I also noticed the rear fog lights didn't work (the switch light flashed on, but turned off after a second).
    I put this down to a coding issue, and using VCDS I checked the following channels in module 46: Central Convenience
    181 - 65535
    189 - 16383
    191 - 16143
    195 - 14852
    196 - 14884
    197 - 14980
    198 - 15012
    203 - 8266
    204 - 82998
    I understand these codings are for the standard halogen? I found a guide that recommended the following changed to code a halogen unit to a pre-facelift led that recommended the following changes
    181 - 65535 to 64608
    189 - 16383 to 16380
    191 - 16143 to 16383
    195 - 14852 to 5125
    196 - 14884 to 5157
    197 - 14980 to 5124
    198 - 15012 to 5156
    203 - 8266 to 73
    204 - 8298 to 105
    However I understand these instructions are for people using a Kufatec loom for a halogen to led retrofit and are possibly for a coupe. I really need the standard VCDS coding for a 2010 convertible pre-facelift rear LED unit; does anybody have these, or know where I can get them?
    If not, are there any pre-facelift convertible owners that have VCDS that could do me a HUGE favour and check the values in the following channels in module 46 - adaptation (you'll need enter the security access login prior to entering the adaptation section, the codes are 41067 or 16017 - 16017 worked for me).
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    I realise this is a big ask and it will take a few minutes, but it would really help!! I beleive channels 207 and 208 relate to the indicators, but I'd like to check all the codes to be sure!
  2. rookie
    rookie Member
    75
    14
    So I finally managed to get this resolved. I tried the many suggestions given to me on various forums, but unfortunately none of them worked. I finally came across a post where somebody posted up the coding for Sportback with pre-facelift LEDs (they use the same units). I tried this coding and it worked! So for anybody else that has the same issue with factory fit pre-facelift LEDs the coding required is as follows
    185:65535
    195:5124
    196:5156
    197:5251
    198:5283
    199:12
    200:44
    201:133
    202:165
    203:73
    204:105
    205:13
    206:45
    207:5
    208:37
    209:0
    210:0
