Tyres Pressures for my TDI
Djwoody Feb 5, 2013
  1. Djwoody
    Djwoody Member
    481
    21
    Hi.
    I have been trying to find an answer to this for a while and its like a minefield.
    Does anyone have recommended pressures for 225/35/19 on a 2008 A3 2.0 TDI 3dr?
    I can only find pressures for 18"s and the 19" pressures vary from 30psi to 40psi!
    Would 35psi be about right for the weight of the car?
    Chris
  2. lau06275
    lau06275 Member
    42
    The recommended ones should be on the inside of your fuel filler flap
  3. Djwoody
    Djwoody Member
    481
    21
    They will only be for 18s though as the TDI does not come with 19s as standard.
  4. lau06275
    lau06275 Member
    42
    Apologies, wasn't thinking properly. Can't imagine they would be much different though.
  5. bennyball
    bennyball Member
    138
    24
    I would have thought that it would be pretty similar to the 18s as the width is the same. Although saying that i am shocked that the recommended presure for mine are 38 front and 35 back unloaded!
  6. Rom
    Rom Member VCDS Map User
    443
    Run what feels right. I'd start with the 18" pressures and then experiment.
    They are recommend, not the rules. Many people add a few psi for fuel efficiency, some drop a few for comfort or handling.
