Tyre valve caps stuck on??
stewarta13wsb Jan 27, 2008
  1. stewarta13wsb
    stewarta13wsb Member
    139
    Help. As title, the dust caps are stuck on and I need to blow up a tyre!
    Some swine stole the last set and the local garage didn't have normal black rubber/plastic ones so I bought metal ones - obviously cheap **** - and now they won't come off.
    Tried half a can of WD40 but no luck. The whole rubber valve just turns now.
    Other than risk scratched allows at National Tyres and have the tyre removed and valves replaced, any other suggestions??
  2. arthurfuxake
    1,308
    Grip the rubber "stalk" with one set of pliers, and use another set of pliers to undo the caps.
  3. Carpy25
    Carpy25 Member
    279
    try hot water chrome caps are often some type of alloy before plated so may expand quicker than the valve thread , then two pair of pliers as above
    Rob
  4. Oli.
    Oli. Member
    562
    10
  5. Dr. Dave
    Dr. Dave Norn Iron
    17
    Just a thought!!
    Cheers, Dave:icon_thumright:
  6. QuickNick
    QuickNick Member
    97
    Take it to your local friendly tyre supplier and get them to replace the valves. Exactly the same thing happened to an Alfa I had, and no amount of persuasion would get the things off
  7. stewarta13wsb
    139
    Result.... sort of!
    One off eventually with WD40
    2 off with the 2 plier method (but one small scratch on the alloy:sadlike: )
    1 to the local garage (they are very careful) for a tyre off - but harder than normal because the valve wouldn't come out to deflate it first!!) and £25 lighter:ermm:
    I'll not buy those again, and a warning to all - who like me, didn't know the perils of cheepo valve caps!
    Thanks everyone.
