Tyre suggestions!
Funkyfin2000 Feb 1, 2011
  1. Funkyfin2000
    Funkyfin2000 Member
    489
    Hi there,
    I have a A4 Avant 1.9tdi quattro sport.
    I have Avon somethings on the front with the V shape Pattern.
    On the rear I have Michellin somethings and they need replacing. I don't necessarily want to match the Avons.
    any suggestions for the rear that arn't too pricey on Camskill and don't wear ever so quickly in a 4wd!!
    I was looking at the Falken 452's for about £80 a corner.
    Rich
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    1,962
    9
    What tyre size are you looking for?
  3. QuottroA4
    QuottroA4 Member
    179
    I'd recommend Conti Contact 3's but they are about £110 a corner - excellent tyre tho :)
  4. Funkyfin2000
    Funkyfin2000 Member
    489
    235/45/17 as thats the standard size i think for the audi alloys on it.
    thats another question is the name of the allows. They arn't the normal 5 spkoes.
    They have thick 5 spkoes with dips in at the ends. They look a bit like the Ford Focus ST wheels I think.
  5. QuottroA4
    QuottroA4 Member
    179
    Thats the correct tyre size for your car, might be worth you going down to a local tyre place (indy not national) and asking if they the 45's fit the alloys, they should do.
  6. simon.m
    simon.m Active Member
    2,747
    any pics mate i have 235/45/17s and they are 5sp ones
  7. Funkyfin2000
    Funkyfin2000 Member
    489
    will grab some pics now, but they are smiiliar to this...
    Check this site out:
    cars 2002 audi a4 30 quattro sport avant blue mansfield insch
    and look at the BLACK A4 Auto - Audi a4 avant quattro sport auto black
    It has the same wheels as that!
    What do you mean check that 45 is the right tyre? You said 235 is right?
  8. Funkyfin2000
    Funkyfin2000 Member
    489
    QuttroA4 - How did you do your EGR mod? Any pics?
  9. simon.m
    2,747
    235/45/17 is the audi standerd size the wheels in that pic are audi one but i can not say if they where standerd on your car sure some one can though
  10. aragorn
    17,893
    689
  11. QuottroA4
    QuottroA4 Member
    179
  12. Funkyfin2000
    Funkyfin2000 Member
    489
    Any guides QuatroA4? Do you have an AVF engine code?
    Hankook?
    I want to match the tread pattern if I can with the front I think.
  13. QuottroA4
    QuottroA4 Member
    179
  14. aragorn
    17,893
    689
  15. Funkyfin2000
    Funkyfin2000 Member
    489
    Will different tread patterns front and back make any difference to handling?
  16. aragorn
    17,893
    689
    Unlikely.
    You already had miss matching tyres on the car anyway, and had the more worn ones are on the rear which makes the car less stable as it is, so what are you worrying about!
  17. Funkyfin2000
    Funkyfin2000 Member
    489
    to be fair the front tyres are fine and one of the rears is fine, just the other rear is very worn on the inside. This is because the person before me changed to the spare (the one worn in the inside) as the original there had a bulge in it! From very unsafe, to slightly unsafe.
    Need to take the decision to relpace both as want the same tread pattern on the rear at least to match up.
    No problem.
  18. aragorn
    17,893
    689
    Yep replacing in pairs is always a good idea, Can always make the better of the three tyres your new spare and replace the bulged one and worn one with new.
  19. Funkyfin2000
    Funkyfin2000 Member
    489
    Yeah thats my aim :)
    what do others run?
  20. quattrojames
    14,050
    573
    I'd recommend Conti SC3's too, they wear well on a quattro car in my experience, and have good wet weather grip too.
    I think they do an SC4 and SC5 too now, I'd be interested to know how they compare.
  21. aragorn
    17,893
    689
    The conti 5p is getting rave reviews, see my above link at tyre reviews for some of the magazine group tests.
    But they're significantly more expensive than £80 a corner.
  22. paul20v
    paul20v Audi fanatic
    1,113
    I run Avon zv3 and have for years
    my mate runs them on his S2 and my other mate runs them on his Mk4 golf TDi
    all good wet and dry and are lasting very well
    also quiet on the road if thats an issue for you .
  23. mikeh126
    mikeh126 Member
    152
    Contis, Avons - both good makes, with good grip and wear.
    I've just put two Goodyear F1 Eagle Asymmetrics on the front of mine ( to be consistent with the make it had on when I bought the car) - the guy came to the house to fit them. Very professional, balanced, new valves, old tyres disposed of for £260 the pair.
    Very happy with the outcome. Can now go and give it some now!!
  24. palfy86
    palfy86 Active Member Audi A4
    364
    75
    Right been here before i have a A4 B6 1.9TDI QUATTRO 130 runnin on 235/35/19s and recently had the rears replaced for dunlops but its eaten through them in less than 4 months (3k miles!!) got some cheap fullruns on the front which were on the car when i bought it 8 months ago and they look good as new. Any advice as to what tyres to try after ive had the camber, toe etc checked out?
  25. mikeh126
    mikeh126 Member
    152
    Chewed throug the rears in 3k miles?? Unless you rally / race it, or do handbrake turns everywhere, there has to be a problem with bearings, camber, under / over inflation etc etc etc.
    There are many good tyres out there - Avons, Continentals, Vredestein- I have Goodyear Eagle F1s on mine, and I'm very happy with them. BUT - cost £130 each fitted. If you're only going to get 3k miles out of them, it means an expensive tyre bill!!
  26. dejongj
    dejongj Active Member
    165
    40
  27. palfy86
    364
    75
    Been down the audi garage on wednesday this week and had laser alignment done and found that the rear was miles out full adjusment all round and 96 quid later hopefully will see the end of the tyre shredding issues, mpg is now through the roof so i guess it was dragging here heels a little lol.
    No its time to get some new rubber boots on it i guess before the Rozzers give me a tug.
  28. Funkyfin2000
    Funkyfin2000 Member
    489
    Where the hell do you get 4wd dealership allignment for that price?
    Stafford Audi want £170, Stoke audi £250, Stafford VW £205....
    I need mine doing URGENTLY its shredding front tyres!
  29. palfy86
    364
    75
    Local audi specialist mate.
  30. Funkyfin2000
    Funkyfin2000 Member
    489
    Im gonna get a local place (allign my car.co.uk) to do it.....£39.95 plus £20 a change.
  31. palfy86
    364
    75
    Just a update really since ive had the camber etc adjusted. Ive fitted a full set of Yokohama S Drive tyres and ive covered over 6k miles with not a single issue of wear etc and the tyres are running like a dream on the 19s.
  32. marktdisport
    marktdisport Active Member
    1,195
    15
    midland vw set mine up in norton canes m8.... £30-40
