Tyre/spacer combo for the wide look
Dogtown22 Jan 3, 2013
  1. Dogtown22
    Dogtown22 Member
    251
    Hi all, what size tyres and what size spacers would I need to give my a4 that wide look??? I'm just about to have new tyres fitted so nows my chance,
    2002 b6 t sport with 18inch fat fives
    cheers Steve :)
  2. quattrojames
    14,060
    583
    What width and offset are your wheels?
  3. Dogtown22
    Dogtown22 Member
    251
    Hi James, I believe they are 45mm offset and 8' wide, I can't get to a computer to check ATM, they are 18inch ronal fat five alloys if that helps :)
  4. quattrojames
    14,060
    583
    You probably want a final offset of 30 then, maybe a bit less depending on the exact look you require.
    235 tyres fit perfectly on an 8J rim, so maybe a 215 if you want a stretched look. See what the others are running.
  5. hades-
    9,481
    646
    20mm rear 15mm front wil sort them
    and tyres as above
  6. Dogtown22
    Dogtown22 Member
    251
    Many thanks all, I might go fir the 225's as they're a little cheaper:)
  7. hades-
    9,481
    646
    yeah 225 will work
  8. Dogtown22
    Dogtown22 Member
    251
    Does anybody know where I can get a complete kit consisting of 4 15mm spacers, all the bolts and a locking bolt??
  9. quattrojames
    14,060
    583
    I bought my H&R from DPM Performance.
  10. Dogtown22
    Dogtown22 Member
    251
    Cheers James, how much we're they and did they include everything I stated in the above?? :)
  11. quattrojames
    14,060
    583
    Prices are on his website, mine were about £70/pair for 8mm and they include longer bolts, but not locking ones, you'll need to source them seperately. Good hubcentric spacers aren't cheap unfortunately, 15/20mm will be significantly more I'm sure.
  12. Andi25th
    Andi25th Member
    227
    17
    Try creations motorsports. £55 a pair for 15mm hubcentric spacers. And there a piece of art.
  13. Andi25th
    Andi25th Member
    227
    17
    Seems there still doing free shipping to. Give them a call.
  14. Dogtown22
    Dogtown22 Member
    251
    Nice one thanks, dont suppose anyones got a pic of their Audi with 18's and 15mm spacers on have they???
  15. Dogtown22
    Dogtown22 Member
    251
    Also, do the t-sports sit higher at the front than the rear?? (looks like it to me) So if I was to lower the car what would I need to do to level things out??
  16. Slinepete
    Slinepete Member
    314
    Do a search for b5 perches that will answer your last question
  17. crazy88
    crazy88 Loving the anonymity
    4,939
    437
  18. Dogtown22
    Dogtown22 Member
    251
    Ahh nice one. Instead of replacing the pear he's and going through the whole pinch bolt nightmare, can't you just use different sized springs to drop the front more that the rear???
