Tyre problem
defer Mar 20, 2010
  1. defer
    defer Member
    87
    Just found a big screw in one of my front tyres. Looking at it it might just be on the edge of the repairable section. If it can't be repaired can i get away with only changing the 2 fronts or do i have to change all 4. Tread on all 4 is down to 3.5mm. Also if i use the space saver is it better to put it on the rear axle? Car is an S3.
  2. smudge_don
    smudge_don Active Member
    2,944
    Space saver should always go on the rear axle
    I believe that a car will pass an MOT as long as the axle has the same tyres, so you can have different ones on the front compared to the back
    But i'd get all 4 done for peace of mind an continuity :)
  3. N8
    17,163
    718
    I'd get all 4 as well..
  4. defer
    defer Member
    87
    Would you believe it, i've carried a can of puncture repair foam for the last 5 years, thought i'll use it on this puncture as i've got 200 miles to drive early AM and didn't fancy it on a space saver, blooming thing didn't work. Grrrrr. Thanks for the replies, i've fitted it on the rear. 4 Michelin pilot exalto's =£660= Gulp. Good job i got 3 new ones off Ebay for £90 each in December.
  5. smudge_don
    2,944
    eBay is my best friend :p
  6. defer
    defer Member
    87
    Mine too. My wife hates it.
  7. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,072
    60
    My gf thinks ebay is a geeky hobby lol.
    They don't understand.
  8. N8
    17,163
    718
    eBay is the one....where else could you find this, people have been searching for this for generations, and I find it on ebay:
  9. Dandle
    Dandle Member
    852
    You could get away with changing only the front tyres if you want. The rears still have nearly 2mm of tread left before they are illegal although most tyre manufacturers recommend changing tyres at 3m due to the massive tail off in performance below that level.
    The space saver can be used on any corner of the car but you need to be aware of the speed limits imposed when its fitted.
