Tyre Pressures
PaulJC84 Oct 30, 2008
  1. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Hi folks, I was wondering if anyone has had a play about testing different tyre pressures?
    I normally just run the recommended level Audi state but wondered if anyone has found any better pressures.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    32 back 30 front on michelin pilot sport 235/40 18's
  3. aragorn
    18,491
    855
    that seems a bit low?
    Our fuel flap recons 32/32 for the standard 205/55r16 tyres but craigs S4 recons 35/35 for his standard wheels, i presume because of the lower profile tyres and the heavier car?
    your quattro should probably be on higher pressures than a stock FWD...
  4. Siena
    Siena Active Member
    2,626
    42 / 42.
  5. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    is that not a little on the high side? also is that pressuse for standard tyres?
    i've got mine at 34 / 34 as recommended by car pressure check thingy.
  6. 205man
    205man Active Member
    1,072
    14
    im running my around the same 42 front and rear thats what i was told by the company that fitted my wheels with 225/40/18
  7. Siena
    Siena Active Member
    2,626
    Nope, not too high, perfectly normal.
  8. aragorn
    18,491
    855
    where did you get that sticker from Siena? thats not a stock A4/S4 item? Is it an RS4 one?
  9. Siena
    Siena Active Member
    2,626
    Ah yes, it's an RS4 sticker.
    I ordered it, fuel grade sticker, along with the in-door barcode stickers, and the airbag replacement stickers, when I was ordering all my RS4 parts pre-surgery.
  10. ALPINE
    3,093
    i run 32 all round.
  11. Oranoco
    Oranoco Well-Known Member
    3,974
    405
    Snap. Might hae to up mine a little
  12. jcb
    4,132
    13
    skits all over the place at anything over 35psi
    used to run 35 all round, 1psi and I can feel it now
    slightly higher rear pressure give a perfect balance of slight oversteer in conjunction with my coilover settings.
    god knows what 42 would feel like with my coilovers! would have no teeth!
  13. Fraser
    Fraser Member
    584
    17s - 36 front 34 back
    18's 38 front 36 back
  14. andybnwc
    andybnwc Member
    752
    this is interesting i used to run 42 42 then was told that it was way too high when puchasing new tyres and put them to 34 34
  15. Izzy1
    395
    10
  16. Z82
    Z82 Member
    454
    18 x 225 x 40
    38 all round
  17. aragorn
    18,491
    855
    tbh i'd rather believe the pressures audi recommend over what some guys on a forum have set theirs to. The only thing with that RS4 sticker is the pressures are for 255/35's and the 225/40 pressures are for mud and snow tyres, so perhaps not ideal for a road tyre. Be interesting to look at a B6 A4 which had 225/40's as standard and see what it recommends.
    There is a way to check though, iirc it involves using chalk on the tyre and seeing if it wears off faster on the outside or middle.
  18. Izzy1
    395
    10
    you willing to try it out? if so let us know of the out come. lol
  19. Siena
    Siena Active Member
    2,626
    ragorn, I understand.
    But I'm running the pressures for the 255 tyres.
    The M+S 225's are even higher rated, at 48 / 48.
  20. Siena
    Siena Active Member
    2,626
  21. aragorn
    18,491
    855
    well i'm running 205/55r16's so i doubt thats much help for you...
    Basically you draw a chalk line across the tyre and drive a bit (not sure how far, might only need a few feet, or perhaps a little further) then look at the line. If its worn off at the outside more then its too low, if the middle has worn off its too high. If its all worn off you drove too far ;)
  22. aragorn
    18,491
    855
    your also running the pressures for 255's with the car fully loaded, ie 5 up and a boot full of luggage... driving about yourself should be using the 36/34 setting...?
  23. Siena
    Siena Active Member
    2,626
    The fully loaded pressure most of the time, yes.
    Most of the time though, my car has a lot of weight in it.
    The width of the tyres means excessive centre wear due to overinflation is very unlikely to be an issue.
    Underinflation however, will definitely cause problems.
