Tyre pressures on 19's
Bondy68 Jul 29, 2012
  1. Bondy68
    Bondy68 New Member
    Hi guys, just had 19's fitted to my 2007 A6, 2.0 TDI SE, tyre sizes are 235/35 x 19, the dealer set them to 34 psi all round as a default setting, just seems a little bit floaty, any recommendations greatly welcomed.
  2. fishyfish
    fishyfish Member
    126
    40
    I have a 3.0 TDI on 255/35/19, and I tend to run mine high (44 front, 38-40 rear) for better economy, plus I prefer the sharper/lighter steering feel it gives. You could prolly get away with less at the front, due to the lighter engine.
    In any case, the recommended pressures should be on a sticker on the fuel filler flap ;)
    AutoJack likes this.
  3. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    yep, photo of filler cap sticker needed
  4. racing6
    racing6 New Member
    I have a 2.7V6 Quattro avant on 19"s and the recommended pressures are 42 on the front and 38 psi on the back. It's more on the front due to the weight of he engine.
    Suprised fishy fish runs more, but might try those pressure myself to see if it makes a difference to handling or mpg.
    chers
  5. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro s tronic saloon
    1,511
    387
    My Avant is 2005 2.0L and I have 19s and ruhn them all at 34 all round... is this stupid pressures?? :S
  6. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    I think there is an element of personal preference in what pressures you choose to run. I run my 235/35/19's at 38PSI front and 34PSI (S3, not A4), and although the manufacturer recommendation is higher I just find the ride quality is a just too jarring at recommended pressures (42/38). If we put luggage / weight in the car we always adjust up, but the biggest issue other than economy is that you could suffer from uneven tyre wear if you have a massive difference over OEM spec. I'd be inclined to ramp it up a few PSI, anywhere within about 10%+/- shouldn't be out of the question.
  7. hazey7
    hazey7 Member
    170
    From personal experience, my 255/35/19s have to kept at the makers recommended pressures, 44/38, otherwise they will not wear correctly.
    You soon get used to the bone-jarring, wince-inducing, spine-smashing, noisy unforgiving ride.
  8. vince31
    vince31 New Member
    According to the sticker in the filler cap my 255/35/19s should be at 44 Front and 38 Rear when car is lightly loaded (3 persons with no luggage). When the car has more than this the sticker shows that they should be 45 Front and 48 Rear. The manual recommends keeping the tyres at the higher value if you don't want to keep changing the pressures with loads, so I've decided to keep all 4 of my tyres at 48 psi. They were all at 39 psi when I bought the car 2 weeks ago and all 4 tyres showed signs of more wear on the outer shoulder, so the higher pressures I now use should correct this and allow them to wear more evenly across the whole tread width. At 250 quid per tyre I want them to last! The ride isnt too harsh, not as bad as my wife's S3 anyway.
  9. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    On the C6 the 19's should have 255 tyres fitted.
  10. sined
    sined New Member
    Lower profile tyres run higher pressure to help avoid damage to the rim.
  11. Bondy68
    Bondy68 New Member
    Update, have changed the tyres to 255/35's and running them at 38psi front and rear, putting the correct size ratio tyres has made a big difference, 235/35's are just too low a profile. Much more settled a ride now, thanks for all the replies as well.
  12. hazey7
    hazey7 Member
    170
    No Mr Bond, I expect you to etc etc etc,
    You should run the fronts at 44 otherwise they will not wear properly......
  13. ChrisFurlong
    ChrisFurlong Avantageous
    343
    Any ideas what I should run my S6 wheels at? Think there 265/35/19 tyres.
  14. a6_chris
    1,883
    160
    They'll be inside your fuel filler flap
  15. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Tyre pressure should be kept the same. Same pressure just a different volume of air. 19's will feel more harsh as they a lower profile and stiffer side wall.
  16. dentsy
    dentsy Loving my new to me allroad
    768
    53
    Anyone know what it should be for a C6 allroad 2.7 tdi now runni g on 255/40/19 tyres.
    Getting very conflicting quotes on pressure from 34 to 40 psi
  17. Simon968
    Simon968 Active Member Team V6 Audi A6 Audi Avant Owner Group S-line owners group TDi
    239
    33
    I'm guessing that you've checked the sticker on the door pillar and the handbook?
  18. dentsy
    768
    53
    My sticker does not show this size
  19. Simon968
    239
    33
    Does it give any pressures for 19" tyres?
    My friend has an All Road, but I'm sure the tyres are 255/35 x 19 on his.
    dentsy likes this.
  20. dentsy
    768
    53
    No mate in mine i only have this
  21. Simon968
    239
    33
    Ok, I'll check my friend's car next time I see it and have a look to see if the sticker is any different.
    Theirs is a V8 petrol one though and has the 19" Speedlines on.
  22. dentsy
    768
    53
    Ok thanks mate
  23. niedzial1983
    niedzial1983 Active Member
    237
    100
    43
    Sticker on mine
    2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
    dentsy likes this.
  24. dentsy
    768
    53
    Ok cool do you think it may be slightly lower presdures for the allroad? Cos of the air suspension mate ?
  25. niedzial1983
    237
    100
    43
    Have a look
  26. dentsy
    768
    53
    Spot on matey thank you
  27. niedzial1983
    237
    100
    43
    Also found this [​IMG][​IMG]
    dentsy likes this.
  28. dentsy
    768
    53
  29. Mollygoogle
    Mollygoogle Member
    252
    Saves me starting a thread! I'm on 19's but like one of the posts above the sticker in the car only goes up to 18"
    dentsy likes this.
