Tyre pressures for comfort
macpdm Nov 3, 2012
  1. macpdm
    macpdm Member
    403
    Morning all
    I checked the pressures this morning on my 8P2 2.0 TDI and the fronts were about 25psi and 24psi on the rears. I checked the fuel flap and increased the fronts to 30 and the rears to 29. The ride is a good bit firmer now but to be honest I preferred the ride with the pressures as they were. The car rode a lot softer and the steering didnt feel any less direct but by running under the recommended pressures I assume this effects fuel economy but what about tyre wear etc ?
    Thanks all.
  2. Tay
    Tay Active Member VCDS Map User
    449
    54
    Sometimes under inflated tires can cause wear on the outer edge, just something to bear in mind :)
  3. The Engineer
    The Engineer Member
    355
    22
    It's also worse on your fuel economy. I do understand though, the roads near me are a shambles so does not help
  4. dstev
    dstev Member
    74
    I run my Sport on 31 all round and find the comfort fine. I'd rather protect the tyre wear and fuel economy.
  5. Tay
    449
    54
    Swerving potholes becomes impossible because the whole road is one continuous pothole?
  6. macpdm
    macpdm Member
    403
    Thanks all Ive dropped the fronts to 28 and the rears to 27 from the recommended 30 & 29 which seems a nice compromise.
  7. The Governor
    The Governor Active Member
    525
    75
    I'm pretty sure my TDi Quattro says 36psi rear 42psi front, so that's quite a long way down from those values...?
    aar007 likes this.
  8. Tay
    449
    54
    My S3 says 39psi front and 30psi rear. But the engine will most probably weigh more in my car than some other models.
    I'm curious what the 3.2 v6 recommends for tire pressures.
  9. fangio
    fangio Well-Known Member
    1,457
    168
    You do realise you can be nicked for tyres lower than the recommended pressures?
    And if you had to claim on your insurance?:redface:
  10. Lewis583
    956
    91
    I'd like to see the police try pull you for slightly under inflated tyres. I'd be willing to bet the majority of cars in the road aren't running the recommended pressures.
    Running the pressures lower than recommended will cause faster wear on both shoulders of the tyre. Which at ~£100 a corner for decent tyres isn't fun.
  11. fangio
    1,457
    168
    So would I, but that's no excuse!
    Plus the extra stress on the sidewalls. Flexing causes heat build-up and degradation of the rubber.
  12. macpdm
    macpdm Member
    403
    No mine states 30 & 29 for lighter loads at most the car has 2-3 people travelling in it with little or no luggage. I think the pressures for heavier loads are similar to those you have quoted.
  13. The Governor
    525
    75
    It depends on what tyres you're running too of course, mine definitely states 42 and 36, here's my pressure sticker in my door... I'm on 18's so the values I use are at the bottom of the sticker:sm4:
    I'd almost thought I'd misread it for a minute after reading this thread...
  14. cloughy
    cloughy Member
    515
    Lol...think the tyres would have to be on the floor! don't know any police officer who carries a pressure gauge
