Tyre pressure monitoring???
killa_z Nov 1, 2007
  1. killa_z
    killa_z Couped Out
    180
    wanted to know if its possible to retrofit this?
    came across this on vagparts and assumed it was a possible add on
    A3 TPMS switch
    Tyre pressure monitoring switch. Two types available:
    For single DIN radio or
    For double DIN radio.
    Please choose below:
    Order number: 8P0927121*5PR
    Our price: 7.78 GBP
    can anyone confirm this? also if anyone knows how to do this if its an easy diy job or if they could point me in the direction of a company/private individual who can do this it would be much apprecited
    thanks
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    I was looking on www.kufatec.de earlier and they appear to sell the necessary looms.
    If you email vagparts they should be able to tell you what you need in addition to the button and will more than likely be able to source it.
    As far as I know there is a cable that connects to somewhere or other and it detects if one wheel is turning faster than the other or something like that, and that is how it tells if there is a difference in pressures.
  3. marms
    marms Member
    833
    I've done this as a retrofit. Its not that difficult at all.
    I actually followed this guide
    http://oooo-a3.blogspot.com/2006/04/tire-pressure-monitoring-system-tpms.html
    Made up my own loom (only four wires.) The above guide is for a left hand drive car but it is basically the same procedure. Main difference is the ABS plug is up behind the battery on the right hand drive cars.
    This is one of those jobs that looks much harder than it actually is. Don't be put off. Nice little upgrade and costs about £10 all in.
  4. killa_z
    killa_z Couped Out
    180
    my battery is in the boot! is my abs still in the same place as yours?
  5. marms
    marms Member
    833
    Ah yeah 3.2 V6.... not sure really. It is right up under the scuttle panel on mine. Top of engine bay and to the right of center as you look at the front of the car. You can't really miss it really. Just stick you head up in the general area and have a look around for the chunk of aluminum with load of tubes coming out of it and a BIG wiring harness connector. I had to remove the battery to get good access to it so I'm not quite sure what you will do if you have a V6 to move to get at it? :)
    Good luck anyway
  6. killa_z
    killa_z Couped Out
    180
    will give it a bash soon (the TPM system) :lmfao:
  7. 1animal1
    9,978
    Anyone done this too? making me moist seing all this stuff i can do to my car :)
  8. Khufu
    Khufu Well-Known Member
    5,704
    31
    Jeeze, a long lost thread LOL
    I'm sure Nigel had done it - little he hasnt lol
    My ABS controller is too basic & would need updated so I've given it a miss.
  9. 1animal1
    9,978
    yeah it does look involving, i suppose the biggest issue is the crimping and cable runs...... would imagine i'll have the ABS sensors to do this
    another thing for me to check on the weekend - just written down all the codes from the FAQs for cupholder, this and the diversity antenna, oh and fan washer jets...enough to keep me going for a bit :)
  10. 1animal1
    9,978
    Take it nobody else has delved into some deflation action.....
  11. NHN
    29,328
    1,708
    Yesh it is one of my completed additions.
  12. roman3000
    roman3000 Member
    316
    If your going to do this mod can you put a guide up and let us know how you get on, ive only found one guide for it, would be nice to have one on this site. Im going to do this in the summer when uni finishes.
  13. 1animal1
    9,978
    well done Mish Money Penny..... any problems i should be aware of? seems pretty simple on the face of it, only query i have is the wiring the live to the fuse board - the guide in the FAQ's shows an aftermarket fuse kit but i cant see why i cant use an unused fuse holder? (but then its not in front of me for viewing ;) )
    will do mate, i'll just update this thread with a few pics
  14. TillA
    TillA Member
    41
    How much Nigel? :)
  15. NHN
    29,328
    1,708
    Depends on the systems mate if possible, if you grab vcds of me we can try & do remotely mate :)
  16. Khufu
    5,704
    31
    hi Nigel, you're still recoding the VAG universe I see :)
    did you every get anywhere with the facelift switchless tpms system?
