Tyre pressure monitoring system....
First Ever Audi May 10, 2014
  1. First Ever Audi
    First Ever Audi Active Member
    260
    71
    Out of curiosity, how does this system monitor the tyre pressure?
  2. monopole
    monopole Well-Known Member
    1,154
    466
    wheel speed
    First Ever Audi likes this.
  3. siybee
    siybee New Member
    22
    Tire rotation speed isn't it? Using the abs sensors
  4. gtiller
    gtiller Active Member TeamMisano Gold Supporter Audi S3
    171
    37
    It doesn't!
    It actually uses the ABS sensors to detect any circumference differences in the tyres
  5. andywil13
    andywil13 Active Member
    380
    68
    As far as I know it uses the abs sensors to detect a change in rotation speed
  6. monopole
    1,154
    466
    ergo wheel speed
  7. siybee
    siybee New Member
    22
    So we're all right then, lol
    Foshiznik and First Ever Audi like this.
  8. NHN
    29,298
    1,701
    As above, circumference of each wheel.
  9. Stephen C
    Stephen C Active Member
    259
    37
    How difficult is the initial setup/calibration you have to do? Sounds a bit tedious?
  10. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,479
    1,124
    Pump all the tyres up to the right pressure, then tell the MMI all the tyres are at the right pressure. That's it.
    First Ever Audi and Stephen C like this.
  11. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,701
    1,518
    It is wheel speed which of course is affected by the circumference or the radius. A wheel with a deflated tyre will rotate at a higher number of rpm. But I'm sure with the educated and discerning Audi driver we all knew that?
  12. ivicyrusivi
    ivicyrusivi Active Member
    157
    I personally wouldn't call it a tire pressure monitoring system, it's more of a low pressure warning system. As it doesn't monitor pressure, only warns when there is a definite and significant pressure change meaning wheel rotation is different.
    It only triggered on my a1 when the pressure got to almost atmospheric pressure aka pretty much flat. When I called Audi about the issue they said "it's not a monitoring system"... And will only let you know when it's almost flat - stupid really.... I argued a lot that day lol
  13. Pulp84
    Pulp84 Well-Known Member Audi S3
    2,235
    1,134
    These systems seem to be rubbish at noticing slow punctures. Had one on my A1 and the TPMS never even detected it.
    Think it's referred to as a puncture warning system in the brochure.
  14. ivicyrusivi
    157
    That was pretty much my argument, not useless, but definitely not very helpful lol.
    The brochure and all material I've seen call it TPMS (tire pressure monitoring system)
  15. Pulp84
    2,235
    1,134
    Yep I think I was thinking of my 3 Series brochure. They all merge in to one when you have read them cover to cover a thousand times !
    But new A3 brochure has it as "tyre pressure loss indicator".
    ivicyrusivi likes this.
  16. ivicyrusivi
    157
    Lol know the feeling
    Pulp84 likes this.
  17. Pulp84
    2,235
    1,134
    Think it's called tyre pressure loss indicator now in the brochure which is probably a better description.
  18. ivicyrusivi
    157
    That's better I guess!
  19. M1ke H
    M1ke H Active Member Team Daytona Audi S3
    239
    101
    43
    I'm sure it must be similar, if not the same, as that in my Leon Cupra. This has previously successfully warned me about a slow puncture, well before it was flat, and came on the day after I had the tyres changed last month. I'd not thought/forgotten about re-setting it for the new tyres and it chimed at me the following day. Re-checked the pressures, reset the TPMS and it's been fine since.
    It'll be interesting to see how the S3 currently on order compares.
    chrisboyle999 likes this.
  20. chrisboyle999
    chrisboyle999 Member
    33
    10
    Long sweeping bends can give false alarms, so don't panic if it goes off mid a or b road spirited drive!
  21. cemerson
    4,479
    1,124
    I've had mine go off once when a couple of tyres had dropped a bit (just going into winter so probably that - was only a few weeks after the car was new), but I've had 2 flats since and it hasn't picked up on it before I've noticed them myself due to the noise. It then went off after I put the spare on in each case.
  22. SuffolkAudiMan
    SuffolkAudiMan Member
    89
    I have had my A3 with these monitors since September and to be honest, I think I should have spent the £75 on something else. Shame really. Like a lot of you, I thought they would tell me when my tires needed a top up. They don't.
  23. steeve
    2,701
    1,518
    I hope those with this option aren't put off checking their tyre pressures on a regular basis.
