Tyre pressure monitoring option
AllanG Jan 24, 2014
  1. AllanG
    AllanG Stronic
    338
    214
    43
    I believe that the tyre pressure monitoring option will be a standard fitment for MY2015 cars, but as I'm planning to order very soon I will get a MY2014 build, so I was wondering if the tyre pressure monitoring option is worth adding?
    A friend has this fitted to his Volkswagen, but has experienced several false alarms with it, which are quite annoying, so was wondering if the Audi system is more reliable, and does anyone know approximately how much the pressure has to fall before activation?
  2. PilotAudi
    PilotAudi New Member
    2,352
    479
    Well worth having.
  3. Daz Auto
    Daz Auto Active Member
    623
    169
    43
    Got it on my Golf. Should already be fitted as standard on Audi IMO.
    Seems to activate if there is a 10% difference between the tyres.
    I have not had any false alarms. The system has only activated if one tyre is 3-4 psi different than the rest.
    With modern suspension it can be difficult to notice/feel if a tyre is flat. With 17/18 and especially 19 inch tyres it can be difficult to visually see if a tyre has lost pressure. If you drive on a flat tyre it will destroy the tyre and could easily damage the alloy.
    It activated when I had a screw through a 1 week old tyre. Replace a £100 tyre or £7 to repair?
    There is also the safety and fuel economy considerations of always having your tyres at the same pressure.
    Having said all that - a friend had all his tyres deflate at the same rate on his BMW. 4 new tyres needed. Though modern systems will detect this. AFAIK the Golf takes readings for the first 100 miles to get a baseline measurement of the rotation of the tyres at various speeds.
  4. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    The system will not alarm if there is a gradual loss of pressure in all 4 tyres simultaneously.
    ie: You still need to check your pressures regularly and replenish air lost through natural diffusion.
    It will alarm if the pressure in one or more tyres differs from the stored value, in a relatively short time span.
  5. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,189
    1,832
  6. veeeight
    6,849
    4,760
    UK Spec Audi S3 1st generation Indirect TPMS
  7. Toadoftoadhall
    Toadoftoadhall Active Member
    299
    80
    I thought the system worked by comparing the rotational circumferences? any difference between these measurements would trigger an alert ?
    Ps Daz auto's BMW mate - all 4 deflating at the same time? Sounds like a Police Stinger to me !!!!
  8. cuke2u
    6,189
    1,832
    Yes it uses the ABS sensors. The article in wiki suggests that the system can be updated to the 2nd generation using software asp. Wonder why Audi haven't done this.
  9. AndyWilo
    AndyWilo New Member
    9
    Does anyone now if you already have your new A3 can the sensors be fitted after?
  10. cuke2u
    6,189
    1,832
    The sensors are already there, it is just enabled in the VCDS...
  11. AndyWilo
    AndyWilo New Member
    9
    So does that mean I just get my dealer to enable it and pay him or can anyone do it if they have the know how?
    Daz Auto likes this.
  12. Daz Auto
    623
    169
    43
    If only it were that simple. Though maybe Audi are different.
    My GTD arrived without the TPMS. I had emails showing I had requested it. When I was picking up the car I asked the dealer to show me where the reset switch was. It had not been fitted. It was the one optional extra that I really wanted, as I do so many miles. If they had left off any other option I would not have cared.
    Do Audi use a reset switch or is there a setting in the MMI.
    Initially I was told that the dealer could not retro fit the switch and enable it. Though they did it eventually.
  13. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,578
    1,175
    It's in the MMI
  14. cuke2u
    6,189
    1,832
    My last car had TMPS as standard and it was also controlled though the car systems, never a switch. I would have thought that any system that works through the car's ABS would be this way and only the system that works through the valves would have a switch...
  15. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    Had a switch in my MK5 golf, and it was using abs
  16. cuke2u
    6,189
    1,832
    I guess as it is a Golf then.....
  17. PilotAudi
    2,352
    479
    Don't think mk 5 golf had TPMS !??
  18. h5djr
    9,439
    1,757
    My existing 8P Sportback uses the ABS and has a switch on the dash. It is used to set the system if you change the tyres or use different tyre pressures according number of passengers and amount of luggage being carried. As far as I know it does the same as the item included in the 8V MMI screens.
  19. PilotAudi
    2,352
    479
    Our 2011 8P had a function in the settings on the display to reset the TPMS . There is no switch. Ours was a Black Edition quattro. Lesser versions may be different. Cuke is correct .
  20. cuke2u
    6,189
    1,832
    The whole concept for the interior of the 8v was to minimise the number switches. So hence no switch, its not needed anyway...
    cemerson likes this.
  21. ETH Dave
    ETH Dave New Member
  22. ddscot
    ddscot Member
    61
    It definitely works anyway, even tells you which wheel it is and to recheck them all, found that out fairly soon after getting mine (why do we always get punctures on brand new tyres)
    Mine had a screw right through the centre and was hissing air out like nobody's business, wouldn't have noticed until it was flat otherwise as couldn't feel it at all.
  23. h5djr
    9,439
    1,757
    Having had two new front tyres fitted today I found that, in fact my 8P does not have a switch. When I looked quickly the other day I confused it with the ESP switch. It is does through the DIS system even on "Lesser versions".
  24. snowfree52
    522
    125
    43
    yes they did :
  25. TTP2120
    TTP2120 Member
    47
    13
    So is this standard in thee A3 Sport back S Line 15plate?
    Like many have said before it's hard to notice on huge rims and tyres on my last car were just ridiculous!
  26. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Yes. It became standard on all MY15 cars built from late May 2014.
    No dash buttons though (as in pic a few posts above) - it is set via the MMI.
    John.
    TTP2120 likes this.
  27. cemerson
    4,578
    1,175
    It's a legal requirement for all new cars now
  28. WeeDram
    WeeDram Active Member Team Daytona Audi S3
    219
    108
    43
    It may be standard in Europe but it's still a $350 option in Canada. I got it on my MY15 S3
  29. ChiYoung
    ChiYoung Active Member
    148
    41
    You know you can enable it via VCDS for free if you have the VAG cable no?
