Tyre Pressure Monitoring Kit
Sirus Feb 15, 2008
  1. Sirus
    Sirus New Member
    22
  2. Sirus
    Sirus New Member
    22
  3. Twizzler
    Twizzler Active Member
    489
    37
    All you need is a good quality digital pressure gauge and a foot pump. Keep fit whilst you maintain your car.
  4. N8
    17,163
    718
    Lol. I was thinking about this mod, but just seems like a waste, too much effort for too littloe result, I may be wrong???
  5. FELIX
    FELIX New Member
    21
    Correct.
  6. JamS3
    JamS3 Active Member
    2,258
    23
    And far too much to go wrong if you make a mistake.......
    Not forgetting the money to fix it!
  7. marms
    marms Member
    833
    I've done it and it really is not as bad as the write up makes it look.
    Basically four wires and a bit of VAG-COM.
    Ok, it's not a job if you are not DIY minded but it is fairly straight forward.
    The instructions in the link show the ABS pump down on the left side of the engine but on a RHD car it is high up under the scuttle panel behind the battery. Much easier to get to.
    As to if it's worth it? Well the bits cost about £10. Ok it's not a must have but I'm quite pleased with it. It is another button to press after all :)
    " He who dies with the most gadgets wins "
