Tyre pressure confusion
Stonefish Nov 27, 2013
  1. Stonefish
    Stonefish Active Member
    174
    50
    Hello,
    I checked the pressures on my 245/40R18 tyres yesterday and set them to the Audi recommended pressures from the drivers door at 41 PSI front, 36 PSI rear. This is for the lowest weight three people. I decided to check a few websites to see what pressures they recommended and got the following results
    Front Rear
    AA 32 30
    Qwikfit 31 30
    Tyresafe 32 30
    National Tyres 32 30
    QI (normal) 32 30
    (heavy) 35 39
    There are more but you probably get the picture. All these sites correctly identified the car and tyres from the Reg no. I'm really tempted to lower my tyre pressures. Is there a reason Audi's recommended pressures are so high? I know my spine would agree.
  2. jpa1992
    jpa1992 New Member
    Which model do you have exactly? I have the same tyres and the sticker on the door recommends 32PSI on the front and 29 at the rear?
  3. Stonefish
    174
    50
    Its the 3.0TDI Quattro. Feels a bit hard.
  4. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 TDi
    520
    Firstly look at how the tyre's are wearing and secondly how the handling feels.
    If the tyres are wearing more towards the outer edges hopefully your tracking is ok but that means the pressure is too low so all the weight is on the shoulders and the tyre's will shuffle giving a woolly steering response.
    If they are wearing more in the center they are too high and ballooning out this will give a skittish ride.
    Its finding what suits you more to be honest.
  5. jpa1992
    jpa1992 New Member
    I have a 2.0 TDI, so obviously yours is going to be heavier, but would the weight difference really warrant an increase in 10 PSI? Seems pretty high!
  6. jojo
    28,831
    3,485
    Just drop them and see how they feel, they are only 'recommended' tyre pressures. On My Passat Estate TDI, I run 32 front 35 rear, I drop the rear pressures if I'm carrying passengers long distance. Just play around with them until you feel it's right.
  7. Stonefish
    174
    50
    Thanks for the replies. I will try dropping them a bit and see how it handles. Definitely seems a bit frisky on bumpy roads in the wet.
