Tyre help!!!!!!!
phantom Jan 24, 2008
  1. phantom
    phantom On Boost
    1,750
    I have a puncture , i'm on my wat to the nearest tyre place, if i need a new tyre do i have to replace both tyres on that axel?
    I have Quattro!
    p
  2. Dandle
    Dandle Member
    852
    No it will be ok to replace one.
  3. phantom
    phantom On Boost
    1,750
    I had to replace the tyre , they had about 3mil on them , so i replaced them both!
    Mitchalin sport ps2 £320 fitted! Good?
    p
  4. steveg9
    steveg9 Member
    180
    I thought the 'counsel of perfection' was all four at once on a Quattro, with a pair as a minimum (unless of course the survivor is 'nearly new')?
  5. L60N
    L60N Guest
    Robbed. Always try blackcircles.com first
    trouble is your local fitting centre may have to wait to get them in so in your case, it may have been the only option to get them done where u did.
  6. phantom
    phantom On Boost
    1,750
    I needed tyres today, i thought it may of only been a slow puncture!
    I only paid 24pound more at National tyres than blackcircles could do em for! not bad really! Oh and i got the warrenty free, free puncture repair for the life of the tyres, if they cant fix the puncture , they will give me a new tyre, or 3/4,1/2,/1/4 off the replacement depending on the tread!
    p
  7. Kontraband
    Kontraband Active Member
    2,003
    yeah, Id be happy to pay £24 extra to get them there and then and the 'additions'
  8. JamS3
    JamS3 Active Member
    2,258
    21
    I think its only advisable to replace all four at once on a permanent four wheel system. Quattro is predominantly front wheel drive until tyre slip so only changing one should be ok. I have done this on my current S3 and previous 2 8L S'3s with no problems.
  9. L33TAY
    L33TAY Member
    344
    How long you had your car Phantom?
    3mm left on the tyre, what is on from new, is it 5 or 6 mm??
  10. steveg9
    steveg9 Member
    180
    new ones 'should be' 8mm. The P Zero Rosso's on my car were a bit under 8mm at 25 miles!
  11. Matt
    Matt Active Member
    1,404
    More often than not when you get tyres from online it doesn't work out any cheaper than buying from a garage as you still have to pay for someone to fit and balance them. Only really works if you know someone that can fit them for cheap or nothing at all
  12. sprout99
    sprout99 Member
    373
    I just got a michelin PS2 fitted for £135 all in 225/40/18 92Y XL
  13. N8
    17,163
    718
    I'm gettin falkens for £105.40 on a 235/35/19 when I get my rims on there
  14. L60N
    L60N Guest
    Not with Black circles, the price you pay includes fitting & balancing etc. Blackcircles use approved fitting centres around the UK, for example mine is Niddvale Vauxhall in Harrogate, a huge workshop with a large stock of tyres.
    My comment regarding having to possibly wait for a tyre was meant really to cover the possibility of somebody wanting an unusual size. Trust me, eveytime ive ordered a tyre through black circles, ive merely had to ring niddvale with the order ref and go have it fitted, its that simple.
    And no, i dont work for them :laugh: , im just a very satisfied customer :icon_thumright:
  15. phantom
    phantom On Boost
    1,750
    Michelin pilot sport ps2 X 2 , 320 quid fitted and warrenty , dont forget i only went in for a slow puncture , so i had no choice!
    So when you way it up, it's not a bad price for decent tyre's OFF THE PEG!
    p
