Tyre air pressure warning thingy
TQS Mar 19, 2011
  1. TQS
    TQS Member
    276
    I can't find the manual (before anyone asks!) as we've recently moved house and everything is everywhere but i'm sure that the pressures on my 55 plate 3.2 SB are looking a bit low and have been waiting for some alarm to come on to tell me so.
    I have the button thing on my centre console but can someone point me in the right direction as to what i#m supposed to do when i adjust the pressures
    Also - what pressures do folk find best on the 3.2 SB?
    :icon_thumright:
  2. ryanstewart9
    ryanstewart9 Member
    494
    If memory serves correct, once you have the pressures set you hold down the button until you here a beep. May even get confirmation on the DIS but can't remember.
    Correct tyre pressures should be on the inside of your fuel flap.
  3. TQS
    TQS Member
    276
    Thanks - will give it a whirl!
  4. NHN
    29,328
    1,708
    Yes Ryan is correct & dis confirmation is with MY10 cars onwards, only a lamp lights in pre MY10 cars.
  5. 1animal1
    9,978
    what exactly does the DIS info show on the My10's + Nige
  6. NHN
    29,328
    1,708
    Just a warning icon afaik to indicate a tyre pressure check needed, it doesnt monitor each wheel as it uses the abs sensors to monitor the circumference of the wheel turns, although the US has a tyre pressure monitor that uses valve sensors, but this also only has a warning not a wheel specific.
  7. 1animal1
    9,978
    ah so no point in going down the US route either...... ****
    nearly fitted mine, just cant be arsed to attempt the ABS plug - seems far to much of a pain! :)
  8. NHN
    29,328
    1,708
    Lazy arse, get your head in there & finish the job.
  9. 1animal1
    9,978
    battery removal isnt enticing ;)
  10. NHN
    29,328
    1,708
    Oh come on, you have vcds now, doesnt take long mate, pull your finger out :)
  11. 1animal1
    9,978
    yarp yarp..... i'll prob do this weekend, just like I was going to last wkd :p
