Two Piece Projectors
diarmuid May 3, 2005
  1. diarmuid
    diarmuid Member
    81
    Just wondering is it a big job to fit two piece projector headlights lights? Is there a bit of hassle in getting them aligned right etc. Also will the existing motors work with the projectors (i've asked a guy on German e-bay and he said it would, just wanted to make sure)? I've heard that the fittament is not quite as good as the one piece ones but are they really that bad? Also, is there a big difference in performance with the projectors over the standard headlights (pre-facelift model)
    I was tempted to fit the one piece projectors but the un-reversible modification of the wing is a bit daunting. I reckon I can always replace the original lights and sell the two piece projectors on when I go to sell my car. Might even recoup most of the money I buy them for too if I buy them from German Ebay /ubbthreads/images/graemlins/cool.gif
    Any thoughts would be appreciated,
    Thanks /ubbthreads/images/graemlins/beerchug.gif
  2. ajmackie
    ajmackie Member
    922
    if buying from german ebay, make sure they switch from left hand drive to right hand drive or your beam pattern will be all wrong.
    optics aren't as good and finish isn't as good. not sure bout motors but guess so. also the indicators they come with are normally different looking.
    i angle grinded my wing and ain't regretted it! makes sooooo much difference to the look of the car!
  3. Broken Byzan
    13,237
    465
    i am more than happy with my 2 piece projectors, the light is much better than STD. I did have to fiddle around a little to adjust them to fit tidily, other than that, well happy.
    The motors fit perfectly and work too. I got the clear indicators and philips diadem bulbs in.
    also the wiring is a straight swap, no soldering/joining looms.
    That said, i will soon be looking to go for the 1 piece units, just for the OEM look and HIDS
  4. diarmuid
    diarmuid Member
    81
    Cheers for the info. I would definitely go for the one piece but don't like the idea of a irreversible mod.
    I saw an S4 the other day with two piece prjectors and it looked quite sweet. However, I guess they are OEM (BOSH?) so the quality would be much better. I take it the original two piece S4 lights are Xenons only and would proably be quite expensive?
    I'd appreciate it if you could post some pictures of your projectors Mawhitey (just to see the fitting you managed to achieve with them). /ubbthreads/images/graemlins/beerchug.gif
  5. you say irriverable, but you can still put the old headlights in fine and you cant see the bit you cut out.
  6. audiwerks64
    audiwerks64 New Member
    why dont you check out the online shop at carisma styling
    http://www.carismastyle.co.uk/acatalog/index.html
    if you go down the page a little, they are there, and there design for the original A4s with the seperate side repeater.
    I will be purchasing a set shortly, so ill put up some pics!!!!!
