Two little A3 questions...
Oli Watts Apr 12, 2013
  1. Oli Watts
    Oli Watts New Member
    Hello Chums,
    Got an A3 s-line sportback on order at the moment. Hooked after a 5 day test drive last week.
    I've a couple of questions about some things that bugged me from the test...
    1 - Is it possible to get the time displayed in the DIS
    2 - Can you set music played over an iPhone 5 to random play? I couldn't make the menu item appear...
    Cheers!
    Oli
  2. Spacemarine
    Spacemarine New Member
    29
    I read in a german forum that this is not possible.
  3. Trebuchet
    Trebuchet Member
    57
    10
    Over bluetooth you could, the car just passes whatever is playing on the phone to the car speakers.
  4. viperfire
    viperfire Active Member
    209
    43
    Bluetooth streaming should be fine
  5. Vertigo1
    Vertigo1 Well-Known Member
    3,477
    632
    1. Yes
    2. There is an option for random playback with my iPod Touch so I don't see why an iPhone should be any different really.
  6. stevey_cam
    stevey_cam Member
    84
    If you stream via Bluetooth and your iphone isn't already set to shuffle then you need to enable it on the iPhone. You can't do it via the mmi.
    I've just got the standard mmi no tech pack.
