Twitchy rear end! 2.8Q avant
Audidave May 3, 2010
  1. Audidave
    Audidave Member
    60
    when in a fast sweeping bend the rear of my car feels unstable (worn bushes)?
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    worn bushes, alignment, rear tie bar/upright bent.
    remarkably soft and bendy if you have ever had a knock or kerb or pot hole
  3. Broken Byzan
    13,237
    465
    Bushes then alignment would be my estimation, i made a different car out of mine by just getting the alignment done. Only one wheel out of the 4 was in spec....
  4. aragorn
    17,954
    701
    Most B5's will be in need of a new set of bushes all round, simply due to their age, So i'd be tempted to throw a set of bushes at it and get the alignment done.
    Would probably be worth doing the front arms too.
  5. Audidave
    Audidave Member
    60
    would you suggest uprated(poly bushes) or oe rubber? i don't want to hear loads of road noise!
  6. aragorn
    17,954
    701
    OE rubber, too many unknown side effects with the poly bushes imo.
