Twin exit exhaust
jolly14 Nov 4, 2009
  1. jolly14
    jolly14 Member
    312
    Hi guys,
    Is it possible to have a twin exit exhaust like the ones on the 1.8t on a 2.0L fsi avant and would i just have to fit a new twin exit valance.
    many thanks
  2. quattrojames
    14,050
    575
    Yes you would obviously need the valance, and an exhaust from either a 1.8T or a 1.9TDi quattro (not 100% on the latter) - and then I think it's just an exhaust hanger required.
    Its quite a popular and worthwhile mod ;)
  3. Niknak
    Niknak Member
    867
    Go for it you won't be disappointed.
  4. JamesS4cab
    JamesS4cab Well-Known Member
    1,190
    94
    Hmmm..........anyone know of a set of back boxes and centre section set up from an S4 cab for sale???
    Ohhhhhhhhh - that would be me then!!
  5. Marc1
    Marc1 Member
    728
    If you are going to use an exhaust from another model remeber you need to take it from a car with the same number of cylinders and only quttro exhausts will fit quattro cars and fwd exhausts on fwd cars - not compatible the other way around. You also need a O/S heatshield, fixing bolts and O/S exhaust hanger. Rear valence required as suggested too.
  6. JamesS4cab
    1,190
    94
    Marc - This is a new one on me! Could you explain? Surely the centre sections, and rear boxes make no difference whatever car it is? Unless you mean the shape of the pipes?? Just wanted to know for my own piece of mind. :blush:
  7. quattrojames
    14,050
    575
    Marc has a pic somewhere I think, but the exhaust is shaped totally different on the quattro's as it has to negotiate the additional diff for the rear axle ;)
  8. paul20v
    paul20v Audi fanatic
    1,113
    Quattro system comes straight down the middle of the car and splits evenly at the centre box ,
    and the fwd centre box is off to the N/S and then the pipes come back across the car the N/S pipe is shorter than the O/S to the boxes .
    there not swapable between quattro and Fwd .
  9. Gaz!
    Gaz! Member
    159
    14
    Sorry to resurect this thread.
    Im looking to do this to my 1.9tdi, could you tell me how many parts of the exhaust are required?
    Reason I ask is I have been offered an exhaust but from the cat back.
    Cheers.
  10. gadgesxi
    gadgesxi Member
    158
    Why do the 1.8T's require twin exhausts anyway?
  11. Martin69
    Martin69 Member
    165
    because it looks sexier
  12. Martin69
    Martin69 Member
    165
    edit : now why did that happen??
  13. gadgesxi
    gadgesxi Member
    158
    the germans stuck them on because they look sexier? ........ok
  14. quattrojames
    14,050
    575
    I imagine it helps the engine breathe, but also looks more aggressive and is a styling touch over the 2.0.
  15. JohnboyC
    JohnboyC Member
    858
    13
    U R showing off now :yum:
    But, would like to do this to my 2.5 TDi Q Sport Avant.....But I want to do it for pennies not mega bucks :)
  16. paul20v
    1,113
    I used the cat back exhaust from a 1.8t on my 1.9tdi the pipe diameter is identical and requires no mods at all.
  17. JohnboyC
    JohnboyC Member
    858
    13
    The back bumper on my 2.5 TDi Q Sport Avant seems to be in 2 sections.....the upper section has the parking sensors in it.....the lower section looks like its separate from the upper section....
    Whats the Part Number for the 1.8T Avant lower section (with the 2 exhaust ports) so I can find one on e-bay and is it an easy job to take the lower part of the back bumper off without taking the entire back bumper off.....
  18. quattrojames
    14,050
    575
    John I can't help you with the part number, but I think marc1 has posted it before. From memory it's not that expensive new, maybe £75 ish plus about £12 for the black sticker....(?) You will need to colour code too of course.
    Thats probably a better bet than eBay, I've BTDT and have two valances sat in my shed which aren't suitable!
  19. quattrojames
    14,050
    575
    I've just found this, the prices are a bit more than I remember :sadlike:
    Unless you can do a NikNak and pick them both up for £50 :ohmy:
  20. Niknak
    Niknak Member
    867
    Come on John it's an Audi so nothing is cheep you should know that!
  21. JohnboyC
    JohnboyC Member
    858
    13
    Yep - I know what you mean Niknak ;-)
  22. Garfie
    Garfie Member
    179
    I need to do the twin exhaust mod soon but not sure on the best way to go about it on a 1.9TDI FWD. I see that getting a 1.8T exhaust is one way to do it but am a bit concerned about then having 2 back boxes. Will this not affect performance or mpg in any way?
    The only other way I have seen is to remove the single standard back box and fit a plain bit of pipe that splits to each side of the car with a chrome tip on it. This way there will be no back box at all and I have the same concerns as above, plus the additional worry of loss of back pressure damaging the engine.
    What effect will having none or 2 back boxes make on the 1.9TDI FWD? Does anyone have any experiences or know of any other way of doing it?
  23. quattrojames
    14,050
    575
    I know of a few (Niknak and Marc1 off the top of my head) who have converted a 1.9TDi to dual exits, and have not heard of any problems.
  24. JohnboyC
    JohnboyC Member
    858
    13
    The more I think about it the more I want to do my 2.5 TDi :)
    Now whats the chances of finding a smashed up 1.8T (will the 1.8T Quattro back bumper be the same as a 1.8T FWD back bumper).... with a Mauritius Blue bumper eh !
  25. paul20v
    1,113
    No issues at all i was worried that the exhaust may get louder by deleting the back boxes thats why i went with the 1.8t system its a direct fit and perfect in every way no change in performance or MPG .
  26. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,926
    199
    So am i clear forgetting the heat shield,hanger and rear valance, it is a system from a 1.8t i want, is that just from cat back?
  27. Garfie
    Garfie Member
    179
    Cool thanks, so a 1.8T back section then add a couple of nice chrome tips?
    This seems the way to go but has anyone else deleted the back box on a 1.9TDI and just gone with the twin exit pipework?
  28. paul20v
    1,113
    Yep 1.8t from cat back the system is even the same bore as the tdi so no mods at all with the system it fits straight on and the genuine sytems come in one piece so the front coupling is the only join .
  29. JohnboyC
    JohnboyC Member
    858
    13
    Ian.....did you have to replace the entire lower part of your bumper or just the bit thats the lower rear vallance with the two exhaust ports......what version/make of back bumper is yours,,,,,and where did you get the exhaust tail pipes sorted ? I would like the same size as the 1.8T myself...
  30. mattyboyc
    1,926
    199
    Thanks for that, this will be my next big project, just need to get the valance sorted then i will have a s-line one in atlas grey for sale!!
  31. Gaz!
    Gaz! Member
    159
    14
  32. theref175
    theref175 New Member
    hey guys and gals, i have a 52 plate 2.5 diesel which has two rear tailpipes and boxes, i would love, love to have chrome exhaust tips, but don't want to do it cheap and nastily but no spend out to much, thing is i have no idea where to go, im in luton, bedfordshire............any advice would be very genuinly welcomed.
  33. mattyboyc
    1,926
    199
    Do a google search for powerflow,there you will find a list of dealers,there's bown to be one near you they will be able to do you some nice chrome tips,personaly i would go for 100mm
  34. quattrojames
    14,050
    575
    Check out POWERFLOW for the tips which can be welded on, and you will need a new rear lower bumper. If you've an Avant I have one you might be interested in.
  35. mattyboyc
    1,926
    199
    Why you not done it yet if you already have the valance??
  36. quattrojames
    14,050
    575
    Because the valance has some minor scratched in it, nothing really, but would suit a car thats got sprayed lowers better. I might yet do it, I'm undecided.
  37. mattyboyc
    1,926
    199
    Well if you decide not to and you wanna sell it cheap, i might have it off you as mine would need painting,but not just yet as i need a waterpump and whilst i'm there i may aswell do annother cambelt so more expense:faint:
  38. Niknak
    Niknak Member
    867
    John,
    The lower part is as per the picture (grey) section, it comes in one piece and has 4 screws, 2 each side behind the rear wheel, then the rest clips in. The tail pipes are the fully monty, 1 x full system.
    Ian
  39. Garfie
    Garfie Member
    179
    Does anyone know if the B7 2.0 FSi twin back box exhaust will also fit the 1.9FWD?
    It looks the same shape as a B6 1.8T one to me
  40. paul20v
    1,113
    Chassis is the same so i cant see why not , and the B7 2.0 tdi fits a B6 1.9tdi so they are the same if you get my drift .
