TV TUNER? little bit of advice please?
harvey183 Nov 11, 2008
  1. harvey183
    harvey183 Member
    Hi all, didn't see a tv tuner as an option when I bought my facelift S3, can't see it on the internet or in the price and spec guide. I've been quoted £700 for an aftermarket fit, Alpine tuner etc and then an interface so it can be used through the controls on the sat nav plus. Full freeview and Dab radio stations etc.
    Does anyone know if the audi tv can be retro fitted and is it digital and at what sort of cost?
    Does what I've been quoted sound about right?
    Just looking for some advice please, Many thanks!:)
  2. s8craig
    1,745
    53
    For 3rd party your about right, but do not be mistaken, it is not DAB radio it is DVB-TV radio stations and are sublect to the same signal issues as normal DVB-TV.
    The OEM system is quite a costly installation, you need the OEM DVB/Analogue hybrid tuner, a cable set for installation, 3x new antenna amplifiers fitted into the tailgate and cables to the TV tuner and brackets in the boot to hold the TV tuner behind the trim.
    Expect to pay around £1200 for the OEM system.
  3. kaz219
    kaz219 Active Member VCDS Map User
    1,808
  4. s8craig
    1,745
    53
    Yes you can get one of those, but you would also need an AV adaptor for the RNS-E to connect the two together. I think for the £700 it will be a similar setup, a standalone DVB-TV box, AV adaptor and installation costs. Hopefully it will a be a nice one which you can control from the RNS-E.
