TV Aerials (x4)- where to put them??
Mcgough Apr 28, 2007
  1. Mcgough
    Mcgough Member
    846
    Although just watched Deal or no deal on the way home and reception was great!
    Has any one fitted them on a AVANT, they are too tall to fit standing up in the side windows? and when lying down get poor reception??
    Also i have 2 green and 2 brown connections on the Tv tuner which one is for which Aerial connection??
    cheers every body???
    Still looking for a switched live behind the NAVI unit if anyone can help me out via Pm that would be great, cheers kris
  2. Mcgough
    Mcgough Member
    846
    This is the left one.....
    This is the right one......
    And this is the tuner....
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    the only other option you have is to remove the panels and either place them vertically in the b pillar behind the trim
    or horizontally underneath the trim in the picture
    try it and see if the resulst are satisfactory or not
  4. s8craig
    1,745
    53
    As I said in my other post, you do not have genuine antennas, it's a shame cos your avant has the antennas built into the windows already, all you need to do is upgrade the antenna amps to TV/radio from radio only and add some cables and you have the genuine system.
  5. Mcgough
    Mcgough Member
    846
    see when i bought them i assumed they where with the original stuff that they where original aerials!!
    where are the antenna amps, how easy are they to change/source??
  6. treblesykes
    treblesykes Member
    690
    Thats a lot of hassle just to watch deal or no deal.
  7. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,092
    2,542
    Yeah, I was thinking that. I've never quite got the point of TV in the car.
  8. madvw
    madvw Active Member
    2,489
    If they're in the same place as the S3, 1 of them is integrated into the rear heated window element. The amp is then behind the hatch cover that covers the rear wiper, lock and all that. Its pretty obvious where it is when you have the cover off. Now idea how many more of them there are, or where....
  9. Mcgough
    Mcgough Member
    846
    you missed my point, Im affraid mine doesnt have them fitted, im after sourcing them to retro fit!!
