Turning on alarm beep and coming home lights
Rigla Feb 4, 2011
  1. Rigla
    Rigla S Line
    How do I go about doing it?
    Midland VW or is there another way
    (Cheapest is best)
  2. hades-
    9,482
    646
    vcds for beep
    parts retrofit for the lights
  3. mike foster
    3,967
    Alarm beep is VCDS. Takes 30 seconds to do but Audi will want £50 ! Find someone local to you with VCDS who is prepared to help.
    Coming home lights need to have auto lighting installed in the car for it to work. It isn't just a case of tweaking the settigs although that needs to be done as well.
    There is a workaround but involves putting in an additional wire to the light switch which then means that locking/unlocking will put the lights on day and night rather than just at night.
  4. mike foster
    3,967
    Bez - you can type quicker obviously!!!. lol :icon_thumright:
  5. kirsty76
    kirsty76 Member
    255
    coming home light can be done with vcds and a repair wire so very cheap mod if you know someon with vcds or already have it
    cominghomelights - audiretrofit2
  6. Rigla
    Rigla S Line
    So can I do the wiring myself and get the VCDS work after?
  7. Smoothie
    Smoothie Active Member
    1,431
    Yea both of those are easily done, the coming home lights link there with the repair wire is no different to OEM except the lights will come on day/night and the beep is just a coding matter also!
    Someone close to you with VCDS couldn't charge you more than £20 for those two things
  8. Smoothie
    1,431
    of course
  9. welshwoody
    welshwoody Member VCDS Map User
    438
    10
    This may sound stupid but as Im interested in this Ill ask.... From the link above theres a paragraph that says...
    "You can leave the light switch at the off position and the lights will go off after the timeout, or you can turn on your parking lights and once the timeout period has elapsed all the lights will go out leaving just the selected parking light(s) on."
    Does that mean that if you have the switch set to DRL as mine usually is, that once you lock the car, after the set time the side lights, dipped lights and tailight will go out, but the DRL`s will stay on?
  10. mike foster
    3,967
    Don't think so !
    Don't the DRL's only work with ignition on ? I think what it means is that, say you wished to leave your sidelights only on, then you turn the switch to 'sidelights' Then after the coming home lights have gone off the sidelights will stay on.
    DRL's have nothing to do with sidelights afaik .
  11. welshwoody
    438
    10
    ah ok, I just thought as its all on the same light switch I meant they would be left on.
  12. N16KSH
    N16KSH Member
    80
    how much do u think auto lighting would set me back as not really in to butget maxing =)
  13. audicruiser
    audicruiser Audi Heaven
    1,865
    New windscreen for a kick off to get the sensors plus it is linked with auto wipers and dimming review mirror. New stalk, new light switch, new mirror etc etc. ££££££££ but it can be done...
  14. N16KSH
    N16KSH Member
    80
    CHEERS PAL THINK I KEEP IT HOW IT IS LOL OR JUST BO THE BUDGET MOD WHERE THEY COME ON IN DAY AND SAVE MONEY FOR NEXT CAR LOL
