  1. gstevens26
    gstevens26 New Member
    17
    Is it possible for a turbo to not work in a particular gear. I've noticed that I don't seem to get as much pull in 3rd as i did. It feels very flat when I put my foot down. I have a 2000 1.8T Quattro.
  2. aragorn
    18,605
    871
    not really, but i guess its possible that its not working in any gear and its just most noticable in 3rd?
    1st and 2nd are over pretty quickly, and 3rd tends to last a bit longer and also is the gear you use most when actually moving, so its quite possible it would seem like the gear affected the most.
    Its possibly a fault which has caused the car to drop into limp mode limiting your boost to 4psi
    Do you have vagcom, and if not whereabouts are you, someone nearby might have a lead.
  3. gstevens26
    17
    I don't have Vagcom no. Is that the diagnostics software? I was messing round with the rear speaker wires from the amp last weekend and I blew the radio fuse. It seems to have started happening after this happened and wondered if I may have shorted something else in the process.
  4. jcb
    jcb Active Member
    4,132
    13
    what revs?
  5. gstevens26
    17
    It was originally pulling around the 3000 mark but I can't say i'm noticing anything before or after that when in 3rd. The car pulls well in 1st and 2nd but i couldn't say for sure that it's due to the turbo kicking in.
