Turbo whine??
djcatfood Aug 18, 2011
  1. djcatfood
    djcatfood Member
    35
    When you can feel the turbo kick in there is a whine noise??Is this normal or is it on the way??
  2. Sheikh
    Sheikh Member
    654
    20
    Probably the turbo spooling mate? What sort of mileage has your car done? Could be a leaky boost pipe.
  3. djcatfood
    djcatfood Member
    35
    96K Mate wats spooling??:/ lol!
  4. Sheikh
    Sheikh Member
    654
    20
    Spooling is where the turbo is spinning up to create boost. Has your car gone into limp mode at all?
  5. RU55SSO
    RU55SSO Member
    792
    24
    normal till it goes pop mate :p
  6. djcatfood
    djcatfood Member
    35
    No not yet! suppose thats the next stage,whats happens when it goes??It's not a loud noise faint wineing
  7. djcatfood
    djcatfood Member
    35
    Cheers mate!! lol!
  8. remslie20
    remslie20 Member
    135
    Mine started to whine, faint at first but then gradually louder. It then started to overboost and eventually after about 4000miles went into limp home mode. Reconditioned turbo later, faint whine is still there(think this is normal although it never used to make the noise???) but driving fine.
  9. matt_hilluk
    matt_hilluk facebook.com/m9tbh
    255
    17
    means its on its way out
  10. Minstadave
    Minstadave Member
    560
    19
    A faint whistle is normal.
  11. djcatfood
    djcatfood Member
    35
    Just a matter of time then!!:/ glad itook AA warranty cover!!
  12. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Whistle is normal, whine could be a sign of turbo on a way out.
    Make sure your warranty covers the turbo.
  13. TAPNET
    TAPNET Member
    89
    Mine does a wooo noise rather than a tish noise in 1st and 2nd then goes away any ideas?
    51k 2.0 TDI 140
  14. Padtwo
    Padtwo Member
    62
    A feint whistle is normal, mine is quite noticeable with the windows open. I have had several cars with turbos, think this one is number six, and they have all done it. The audi did sound a little harsh when I got it but after a service and some fresh oil sounds much better, difficult to describe but the spool up now sounds much smoother.
  15. Stink
    Stink Member
    well this eve i have noticed a very faint sort of whine/whistling sound but this is isn't under heavy acceleration and its before the turbo kicks in then I can just hear it spooling up, does this sound like a leaky boost pipe? not really too sure if its something to worry about only noticed it as i didn't have the stereo on
  16. Sock
    Sock Shark in a Goldfishes clothing
    576
    Mine has a whine on it, but mine is intermittent and sounds more like it's the alternator than the turbo, like a belt whine if that makes sense?
  17. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    I noticed that after changing standard air filter to ITG panel filter.
  18. NHN
    29,351
    1,720
    I think a little bit of scaremongering going on here :)
    Whistle/whine is normal to an extent, however your car has done 96k, the turbo's get caked up inside with sticking internals, now thats not to say yours is at that stage or ever will be, but I would do a scan of the car, if no signs of overboosting or errors in general I wouldnt worry about it, if it bothers you that much then get it looked at, check intake pipes are all tight & in place, check system for leaks, remove turbo check internals & see if its caked or not, also check if the bearings are loose, variety of ways to deal with, but unless you notice any performance differences I wouldnt worry yourself atm.
    Mine went & replaced with a hybrid, my heart sunk as I thought uh oh new engine or car scrapped, luckily (in some ways) it was just the turbo, but the oil had gone into exhaust system, so had to drain this out & then pass liquid through to get rid of any clogged up excess oil, did it all myself, was a ball breaker, but I learnt allot from it & very glad I did it tbh.
    RedDejavu and djcatfood like this.
  19. Tris Harris
    Tris Harris New Member
    my tdi sounds like a police car is following me the turbo whines so much! doesnt seem to be any leakages or anything though...
  20. matt_hilluk
    255
    17
    When mine started whining (after I had only had it 3 weeks) I sent it back to the dealership and was told I needed a new turbo. Which the garage kindly paid for. And now it doesn't make a peep.
  21. S3 finatic
    S3 finatic Limp mode
    106
    As NHN says people are to quick to replace turbos.
    When i bought my 54 plate 2.0TDI there were no whistles or whines, i gave it an oil change (with good quality recommended oil) and within 1000 miles it started to sound like a police car was following. 500 miles later it went into limp mode, this happened several times before i decided to take the turbo off and have a look. It was badly sooted up, but i could not see any wear at all. I gave it a clean with parafin and other chemicals i had laying around in the garage. It was soot free when i put it back together, i have done about 5000 miles since, it has not gone back into limp mode, and i have no loss in power.
    However! I still have a faint whistle/whine, and there has been a couple of ocassions it was quite loud that worried me.
    After reading a few more posts, I then checked my vacuum hoses to my intercooler and noticed oil around the joins, so purchased replacement seals thinking that would cure the noise, but the noise was still there, and when checking the vacuum hoses again a few weeks later, i noticed they were still dispursing a small amount of oil.
    I will be replacing the hoses at some point, but in no hurry while the car is running fine.
    Hope my experience can help!
  22. Mujnu
    Mujnu Active Member
    513
    74
    How do you tell the difference between a healthy whistle and one you should worry about?
    I've got a slight whistle from around 1300/1400 rpm, when the boost kicks in I can no longer hear it. I can only hear the whistle when the windows are up, when they're down I can hear more of a air suction sound if that's makes sense lol
    Any advice would be great :)
  23. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    695
    108
    43
    a healthy whistle is what you'd hear on any turbo diesel you drive past, the siren you might hear (similar to the VXR Bathurst supercharger) coming from your turbo is NOT a healthy sound, and the lift-off dump valve type waste gate sound shouldn't be too excessive either, I just had my turbo removed, stripped and cleaned properly, it sounds like a new turbo, the lift off sound is nowhere near as aggressive and the whistle is now a very civilised one
    Mujnu likes this.
  24. Mujnu
    Mujnu Active Member
    513
    74
    Thanks for that mate. Puts my mind at rest a little ha :)
