Turbo wanted please...
ALPINE Dec 1, 2009
  1. ALPINE
    3,093
    for my AEB please :)
  2. Broken Byzan
    13,237
    466
    Whats up with the replacement one? I didnt expect you to have an AEB in your passat. What age is she?
  3. ALPINE
    3,093
    she be a 98 mate. :) The replacment was apparently the origanl Turbo, tho i cant see nothing wrong with it. need to get it on Vag com asap, but cant get ot working on Win 7
  4. aragorn
    18,605
    870
    Alpine: when you launch vagcom in 7, you need to right click it and choose "run as administrator" then it works just fine :)
  5. ALPINE
    3,093
    tryed that dude... still no workies :(
  6. aragorn
    18,605
    870
    works on mine :p
    What does it do/say?
  7. ALPINE
    3,093
    it just does nothing. tryes to load then gives up
  8. aragorn
    18,605
    870
    Hmm thats not right then
    If i dont run mine in administrator it starts, then crashes when it tries to connect to the engine or whatever.
    I'd try reinstalling it if it wont even launch.
  9. ALPINE
    3,093
    tryed that, wont have none of it. perhaps my copy of vag com is different. :(
  10. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Alpine, I have the same problem. I go to enter a module, ie: Engine, and the whole screen goes pale and it freezes.
    I just re-install Vagcom and it works fine... for one session. Have to do this each time I start it up.
  11. aragorn
    18,605
    870
    mine crashes when you open engine ONLY if its not in administrator mode...
  12. Lee Goodall
    Lee Goodall Active Member
    2,279
    What makes you think there's something wrong with your turbo mate?
  13. ALPINE
    3,093
    0.1 bar boost!!! i know i just come from a 350bhp scoob but i know the pi55rat aint ment to be that slow! lol
    Boost gauge fitted says there no boosty woosty! all pipes checked, DV`s been replaced, as has N75. :S
  14. Lee Goodall
    2,279
    Sounds like the turbo to me mate ;)
    I have numerous turbos to bolt to an AEB.. you want a standard K03 (K03-005 I think)?
    See what VAG.COM comes up with first obviously.
  15. ALPINE
    3,093
    how much you want for a S mate? ill just replace it i think.
  16. Lee Goodall
    2,279
  17. ALPINE
    3,093
    k03 s lol
  18. Lee Goodall
    2,279
    AEB doesn't use a K03s as standard mate.. K03s is from the 180HP models.
  19. ALPINE
    3,093
    i know this ;)
  20. Lee Goodall
    2,279
    I haven't got a K03s lol
  21. ALPINE
    3,093
    then ill have a ko3 lol
    sorry i read your post wrong! lol
    ill get my coat>>>>>>>>>>
  22. Lee Goodall
    2,279
    Ha ha.. easy to get a 5 and an S mixed up.
    If you've got a K03 hotside to hybrid it with I have a K03 coldside with about 95K on it. It's in good condition with minimal shaft play (I said shaft play ha)
  23. aragorn
    18,605
    870
    Lee: the 180hp models didnt actually get the 029.
    The AJL has a 005 turbo just like the AEB. Only the very late 150hp DBW engines got the 029, and all the B6 models got it too.
  24. ALPINE
    3,093
    price? :scared2:
  25. Lee Goodall
    2,279
    So the 180HP runs an 005?.. I thought they ran a slightly bigger version?
  26. Lee Goodall
    2,279
    Errrmmm make me an offer?
  27. ALPINE
    3,093
    16p plus £20 postage! lol
    dunno bud, just PM me a price. i mite just get my TD05 modded muhaha!
  28. Lee Goodall
    2,279
  29. Lee Goodall
    2,279
    PM sent but the TD05 would be awesome!!.. go on.. do it.. do it!!
  30. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    it may just be the penny washer on the waste gate has come off or the actuator is bust. if its the washer you just need the hot side from a blown k03 to replace it with. does it smoke or anything? if not i would look into that.
  31. ALPINE
    3,093
    tdo5 has the same flange, if it would fit in the hole is another story.. Hmmmmm Tdo5, Large FMIc and a map! he who dares my son, he who dares!
    Ill drop you a PM when i need the turbo Lee as im sure the TD05 route is not that simple ^^^^.
    that ok?
  32. Lee Goodall
    2,279
    Yes mate.. just let me know.
    TD05 FTW :)
  33. ALPINE
    3,093
    i will look into a Scooby Turboed powered PissRat! Oh if only! lol
  34. aragorn
    18,605
    870
    I very much doubt the TD05 has the same flange.
    Lee: http://www.vagcat.com/epc/cat/au/A4/1999/223/49/2771536/
    If you look there it has the part number for the AJL turbo, 058145703L.
    The other turbo listed for the APU, ANB and AWT engines is the 058145703J.
    If you look up an AEB, it uses the same 703L turbo, which is a K03-005.
    The 703J is used on those two DBW engines, and most B6's, bar the 190hp BEX engined B6 models. This is the 029, which has 8 blades on the compressor instead of 12.
  35. ALPINE
    3,093
    been told a TD04 bolts straight on an AEB. Alot of yanks do it aparently. As the 04 and 05 have the same fitment i assume a 05 will bolt straight on too!?
    im sure ill be prooved wrong :)
  36. Lee Goodall
    2,279
    Aragorn - You learn something new every day!
    So boosting a 180HP to 210HP must be ringing the little K03 to death!
  37. aragorn
    18,605
    870
    Ye!!
    I thaught the k03s was fitted to AJL's too, but when both docurleys old turbo and marks turbo from unfettled AJL's were both standard 005's i had another look!
  38. Lee Goodall
    2,279
    That's sounds promising.. I'd imagine you'd need to play around with the TIP and connections but nothing too costly.
  39. ALPINE
    3,093
    yes.. basicly i mean... its "doable" without having to bend over for your bank manager!
  40. ian52
    1,199
    My AJL has the k03 as well.
