Turbo upgrade :)
Lee Goodall Apr 28, 2008
  1. Broken Byzan
    13,244
    468
    They fit them to the later cars with small port heads and flashable ECUs for the likes of the hammer file and the K04-15 off the shelf setups
  2. Lee Goodall
    Lee Goodall Active Member
    2,279
    Hmmmm? I thought the TT injectors were supposed to fit?.. not a problem if not but would be much easier to get hold of.
    Yeah the airbox may fit with some tweakage but I think I'll be going down the custom intake route. I'll investigate when I get the kit to see how much space is available.
  3. Lee Goodall
    2,279
    Aftermarket it is then.. no UK suppliers/importers?
  4. docurley
    4,073
    88
    If you get a set of TT unit's I will swap you my 280 injectors I bought SH from the US for my old car.
  5. Lee Goodall
    2,279
    That'd be good mate.. I pressume SH will be ok for the TT injectors? Has there been any variation in the TT injectors through the years of production?
  6. docurley
    4,073
    88
    SH works for me and I have no idea if there has been any change but as long as they are in good working order they should be good to go.
  7. Lee Goodall
    2,279
    Is there any need to upgrade FPR or pump?.. what does the standard max out at?
  8. Lee Goodall
    2,279
    Excellent.. I'm on it as soon as the T28 arrives. Cheers mate.
  9. Drizz
    Drizz Project Plush
    681
    So having my 2000 1.8tqs mapped will only be a generic map? I cant have it 'live' mapped?
  10. Lee Goodall
    2,279
    Yeah you could get a custom/live map and I pressume yours can be done via the diagnostic port too with it being a much later model.
    The generic maps generally push the turbo to a safe limit though so a custom map on a standard/factory fitted turbo wont really be worth it. Custom maps are better for modified setups really.
  11. Drizz
    Drizz Project Plush
    681
    I see, well id like to upgrade the turbo but it does seem a minefield. I just wish there was a 'to do' route, as in:
    You need this turbo, this actuator, and this remap
    Just read so many bits here im even more confused now...
    Ill be having a full milltek and FMIC before anything else is done but from there im lost on where to go and what to buy....
  12. Lee Goodall
    2,279
    My turbo will be up for grabs in a few weeks which will bolt straight up to your existing manifold... With exhaust, FMIC, DV valve, uprated TIP and a custom map you should see 220+ BHP.
    Just pick a tuner for the map that knows a turbo from their A.hole and you'll be sorted.. I'd look to the route of Custom Code or Jabbasport personally.
  13. Lee Goodall
    2,279
    ..all depends on what power you're aiming for really mate?
  14. Drizz
    Drizz Project Plush
    681
    Reliable power. Shame that its such a mission to get to cupra R standard power. Maybe i should have bought one of them instead LOL
    Ive read all youre post but im running a Bailey DV26 so that should be ok as ive used that at 300bhp on a Vauxhall LET.
    Whats the TIP?
    And what will youres be up for?
  15. Lee Goodall
    2,279
    Not sure about the dump valve as our engines use different ways of measuring airflow.. I had an atmospheric DV on mine but it wasn't ideal. A diverter valve will feed the air back into the system but an atmospheric wont.
    The money you'd pay for a Cupra R would def get you to 300hp in an A4 IMO.
    TIP - Turbo Intake Pipe.
    Errrmmm not sure on the price yet.. I'll have a think and let you know.
  16. Drizz
    Drizz Project Plush
    681
    Yeah please do. I was advised that id run into issues with my bailey item but its running fine on my standard engine, and ive kept all the bits i took off just incase....
  17. Lee Goodall
    2,279
    Yeah it's not a power issue.. it's more of a problem with the measured air escaping and the ECU not knowing about it. Could run fine but to be certain I'd use a diverter valve.
  18. Drizz
    Drizz Project Plush
    681
    well if i get running issues ill revert back but for now i like it :)
  19. Lee Goodall
    2,279
    vrummmmmmmmm psssssssssssst vrummmmmmmmmm pssssssssst lol
  20. Drizz
    Drizz Project Plush
    681
    Been a couple of years since ive had a turbo motor so im enjoying the dump for a while LOL
  21. Lee Goodall
    2,279
    Just thought mate if yours is a 180HP A4 then you'll probably only gain 20HP more by using my SP51R anyway over the K03s you already have.
  22. Drizz
    Drizz Project Plush
    681
    I may have to buy a cupra R engine then and make it fit mine LOL
  23. Lee Goodall
    2,279
    Get a K04-15 hybrid (outlaw) as Mark (Byzan A4) is running and you'll see Cupra figures easy.
  24. Drizz
    Drizz Project Plush
    681
    And who retails those?
  25. Lee Goodall
    2,279
    Scroll Products..
    You'll either need to supply a K04-15 for them to work on to make the hybrid or ask them to supply the parts from new. They might even have a second hand unit there if you're lucky.
    Email Sean at Scroll Products.. he knows his shizzle. They made my hybrid K03 and I was very pleased with the service.
  26. Drizz
    Drizz Project Plush
    681
  27. Broken Byzan
    13,244
    468
  28. Lee Goodall
    2,279
    Click the USA flag at the top mate.
  29. Broken Byzan
    13,244
    468
    Docurley and I went for the Full hybrid he was offering that isn't advertised. It's a Sp51X Outlaw turbo, It's based on a K04-15 but has larger hot and cold side and is machined out to take the new internals as well as having Dual feed bearings fitted and being balanced to a high tolerance.
    Mine at the mo is making 250bhp and 270 ft/lb torque, but we are of the opinion that with a new plashable Me7 ECU she is capable of quite a bit more.
    Drizz if you are at GTi Inters, both Lee and i will be there with our different setups, should be good for comparison on the strip,as its a more real world difference than actual power figures
  30. docurley
    4,073
    88
    I had a Bailey DV on my B5 1.8T with no issues at all.
  31. Drizz
    Drizz Project Plush
    681
    Will you be there on the saturday gents?
  32. Lee Goodall
    2,279
    ..saying that though my map isn't good so probably wont be a very realistic comparison as I don't dare crank the boost up too high as the fueling goes way out using a bleed valve.
    Although I'm still up for the Q.mile lol.. Next year I'll be set to take the A4 AEB crown :p
  33. Lee Goodall
    2,279
    I'll only be there on the Sunday as I have a wedding to go to on the Sat.
  34. Drizz
    Drizz Project Plush
    681
    Byzan what was the total cost of youre turbo conversion?
  35. Broken Byzan
    13,244
    468
    From start to finish? As i didn't have a turbo engine in my car originaly. Or to put the Hybrid unit on?
    IIRC it was around $650 delivered from Poland, then the map, which i got from Chipped UK as it was my 2nd map from them from a std K03 map, i had the 2nd second bit at a discount still it was £500 ish for mapping .
    That took me several attempts to get it somewhere near but it's close on std 4 BAR FPR and Injectors. I have since added a high flow Exhaust mani( $100) and FMIC (£400 ish) so i want to get the map tweaked to suit, but will wait until i fathom out the Flashable ECU conversion properly so i can get it done once. I understand Custom Code can do it for a shade under £400, though my first preference is to go to Jabba as they seem to know a lot about these ECUs being used in Golf 1.8t Conversions and the like
  36. Broken Byzan
    13,244
    468
    Yeah yeah,lol:gun2::p
  37. Lee Goodall
    2,279
    Is there a particular MAF that is preferable when upgrading from the AEB to the TT MAF?
    I assume it's from the 225HP TT but there are various different Bosch part numbers available.
    Has Docurley purchased a MAF previously? If so which one?
  38. docurley
    4,073
    88
    S3 or TT225 MAF will do the latter the better I would have thought.
  39. Andy.B
    Andy.B Member
    401
    I just remembered i have a MAF from one of the newer cars ill include it in the kit just to get you running. But ill have to confirm part no's so i 100% know its the newer MAF.
  40. Lee Goodall
    2,279
    Nice one cheers.
