turbo turned up today
s3gazz Sep 7, 2012
  1. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    It would be interesting to know what turbo that was for then!
    I have to ask do you want a clipped tur one or is that what they sold you or you wanted?
  2. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    I asked for the top spec mate and they give me what I had before it was clipped yes pal
  3. s3gazz
    1,383
    105
    your right there bill all depends on who is building it what spec would u go for or recomend bill
  4. Audi S3 freak
    Audi S3 freak Member
    137
    just to add my 2 pennys worth....my k04 died so i got a brand new k04 and got cr to hybrid it. it looks spot on! im yet to fit it as im waiting on my manifold turning up so as soon as it does i will post and let you guys know what it produces as soon as she gets on the rollers.had my brother check it over and hes happy with it so im good with that! hes former p.t.s,a1 rally sport,prodrive, etc etc so he knows his stuff! he has never had any problems with cr so when i told him they get stick on here he told me to relax they have always built him good hybrids! we shall see as soon as my bloody manifold turns up! :)
  5. Prawn
    11,667
    3,666
    CR scare me a bit if I'm honest.
    I have Wellys old hybrid, and it's epic. It's known to make power, and it's come through Bill, yet even he was messed around with dodgy housings and the like!
    What I dO know though, is that when it needs a rebuild (and trust me, IT WILL!), it'll not be going back to CR. I just don't trust that I'd get the same turbo back. I'd send it to Dan as I know he'd do a good job of it.
  6. Westy
    Westy Well-Known Member
    17,443
    1,105
    Why does nobody else rate Turbo Dynamics? They are jut down the road from CR too.
  7. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    jims was a TD one wasnt it. he didnt have any troubles, none that he reported anyway.
  8. Westy
    17,443
    1,105
    I have a few mates that have used them and I've not heard of the inconsitancies that CR seem to have.
  9. badger5
    9,599
    2,060
    my spec is my own.
  10. badger5
    9,599
    2,060
    inconsistent is the issue... they can build good ones.. but also carelessly also send out ones with erratic build spec... Thats an issue.
  11. badger5
    9,599
    2,060
    TD give good prices on new units.. their stage 4 is the equivalent..
    much rivalry between the two Co's I believe.
    I have heard (not experienced) issues on warranty from TD same as I have from CR..... Usual cop outs of blaming oil contamination for bearing failures for example...
    TD would be my other choice or AET
  12. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Both my hybrid K04's came from TD
    As bill said, only real issue is warrenty but they are all the same, Only covered if on a fully stock car. Which it isnt going to be if your fitting a hybrid turbo!
    The price diffrence between TD and CR was huge though,
    CR said something like £650 to rebuild/ exchange my stage 4 TD unit,
    TD said £1300 as it was all beyond repair ?
  13. badger5
    9,599
    2,060
    What do you charge Dan for an equivalent 2283 based RS6 turbine?
  14. s3gazz
    1,383
    105
    Well Ill see what happens when mine comes back worse comes to worse ill get someone else to build it up and mines past warranty so there looking after me really
  15. s3gazz
    1,383
    105
  16. beachbuggy
    1,931
    202
    At the moment They are around £700. That's using the existing turbine housing and compressor housing. With an updated actuator, all ported and completely new CHRA. I'm having a little trouble getting 2283 compressor, I've got some coming in the next 4 weeks, I even had to supply one to TD recently as they couldn't get any!
    All mine are built to order and to the users requirements, I've got a couple of new spec turbos coming out soon and a couple to be tested but I'd like to think as I'm only doing k03/k04 turbos I can offer a more consistent product. Time will tell.
  17. s3gazz
    1,383
    105
    sounds good dan keep it up mate never no might have to come to u if this one goes tits up lol
  18. olly quattro
    olly quattro Member
    78
    i give Dan the vote on turbos, keeps you informed with exactly whats happening and is happy to discuss things with you at length to ensure you have something that will do what you want and is suited to our needs
  19. badger5
    9,599
    2,060
    ok, cheers for that.
    let me know of any developments Dan
    cheers
    bill
  20. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Could you squeeze in a gt28 .....;)
  21. beachbuggy
    1,931
    202
    Gt28 compressor is no issue, nor is gt30 or gt35. My latest build/project has a gt35 compressor in a k04 comp housing. Fitting it in isn't the issue, it's making the thing work. Turbines are a little more tricky, as shaft sizes,lengths, seals, bearings and Iducer/exducer sizes are completely different, add to that the k04 turbine housing is by far the biggest restriction limiting any of these hybrids, just fitting in a gt28 isn't the answer and to be honest for all the cost and heartache you may as well just fit a gt28.
    My main thing I'm looking into is building a larger turbine housing to help back pressures and heat, the hope is to be able to utilise this on hybrids together some decent performance gains, the reason at the moment of running a stupidly big gt35 comp wheel is to see if it will firstly run and secondly flow sensible air, but again the turbine housing restricts the turbo so it's never going to be a practical hybrid and hence the testing, but on the back of this a gt28 compressor wheel may be suitable especially as a replacement for the hard to get of 2283.
    Im getting the opinion more and more the 2283 is very under utilised in these hybrids and similar power could be made with a 2280compressor , hopefully time will tell
  22. badger5
    9,599
    2,060
    gt35 comp wheel? seriously?? OMG!
    thats going to be erm.... interesting...
    did you see the vortex thread and mention of hgp hotside?
  23. beachbuggy
    1,931
    202
    Interesting.. I'd say ridiculous to be honest , it's complete over kill and may flat on its face but I wanted to see what was possible on the cold side keeping within the constraints of the k04 . It's never going to be anything I'd sell but it seemed an interesting thing to try as if a decent hotside can be conceived then running a gt28r or gt30 maybe a more realistic consideration providing costs can be realistic. And having spent a good amount of time getting the gt35 into a k04 I know it can be done for reasonable £'s.
    And if it's a disaster then it's been good r and d
    No
    I haven't read Dougs post but will search unless you could provide a link! Please
  24. badger5
    9,599
    2,060
  25. beachbuggy
    1,931
    202
    Ahh yes I remember you posting a thread a while back on these €800 a piece! Not quite sure it's worth the money but it may be worth trying.
    I think that if these can be made up for a sensible price they may be worth it especially when turbine housings are impossible to get hold or are cheap quality.
  26. badger5
    9,599
    2,060
    they look to machine and insert a piece to the hotside, which is something you might be able to also do?
    another question is one of the eliminator k04 hotsides... and how they compare to k04 bw size wise...
  27. s3gazz
    1,383
    105
    eliminator hot side emm nice thinking bill wonder what the ported hole size is compared to the k04 hot side
  28. badger5
    9,599
    2,060
    I believe Dans got an eliminator hotside already to look see....
    should be interesting how and if that develops
  29. s3gazz
    1,383
    105
    Ye think that would go great with the rest of the k04 bits like u said the hot side is the ristrictive part might buy one off him see how it goes or if I can get one from anywhere and swop them over ha
  30. s3gazz
    1,383
    105
    turbo has arrived again and the hot side looks alot better pics to come
  31. s3gazz
    1,383
    105
    turbo back again and looks better to me
  32. beachbuggy
    1,931
    202
    Well, I have to say it looks good...As turbos go that's pretty pretty.
  33. s3gazz
    1,383
    105
    So this one looks good the dan ha.
    also do I get the turbo checked as don't want to fit and find its like prawns was my last hybrid lasted a year and bearings were worn emmmmmm standered like prawns if ya as me
  34. superkarl
    9,610
    2,481
    you mean regarding the thrust washer?
    id check the actuator pressure and make sure thats right and is set up correctly. they seem to be a big pain on these things
  35. s3gazz
    1,383
    105
    Ye Karl forgot the word ha and ill set the actuator pressure before fitment mate don't want to be behind there altering it with that mani in the way
