turbo trouble
Discussion in 'A3/S3/Sportback (8P Chassis)' started by s3 ginga, Nov 17, 2008.
  1. s3 ginga
    s3 ginga New Member
    Jan 3, 2008
    13
    :banghead:Hi,looking for some help with my ko3 turbo. I have gone through four turbos in four months,the last one only lasting three days!!!! The problem seems to be the turbine shaft inside the turbo keeps shattering. What could cause this to happen? oil feed? coolant feed?any help with this would be great.
  2. Advert Guest Advertisement
  3. s3 ginga
    s3 ginga New Member
    Jan 3, 2008
    13
    forgot to mention this is the 2.0t fsi engine
  4. TFSI
    TFSI Born to Fish
    Jan 10, 2008
    540
    52
    Oil feed or overspeed or dirty oil or blocked oil drain. Is it tweeked ?
    The correct turbo for the correct engine should last the engines life.
  5. s3 ginga
    s3 ginga New Member
    Jan 3, 2008
    13
    i have now purcased the s3 ko4 with all parts to fit on i will change the oil feed pipes before i put the new turbo on the car is running totaly standerd
  6. VRStu
    VRStu Just Looking
    Oct 6, 2008
    1,073
    When the turbo's have been previously changed have you flushed and changed the oil and fitted a new filter?
    Remember you'll need to relocate your DV with the K04, I can give you the part numbers to make an extension wiring loom if you wish. A good opportunity to throw an S3 intercooler at it too.
  7. s3 ginga
    s3 ginga New Member
    Jan 3, 2008
    13
    pm sent:thumbsup::thumbsup:
  8. VRStu
    VRStu Just Looking
    Oct 6, 2008
    1,073
    Replied.
    There are two connectors and the associated repair wires. You'll need about 2m of nice 2 core cable as well. I've also included the number for the corrugated plastic tube to put the cables in to protect them.
  9. s3 ginga
    s3 ginga New Member
    Jan 3, 2008
    13
    cheers mate trip to the dealers then im ready to fit the turbo. well after i find whats shattering the turbine shaft:ermm: forgot to mention that the dealers fitted 2 new turbos under warrenty so guess they would of flushed the system and new oil??
  10. VRStu
    VRStu Just Looking
    Oct 6, 2008
    1,073
    Yes you'd like to think so. KO3's on the TFSi seem to be pretty reliable from what I've heard so very strange that you've lost two.
    One thing to check might be the that the DV is operating correctly, you can plug it in and operate it with VAG-COM/VCDS to check the movement.
