  1. chris1988brown
    chris1988brown Member
    575
    Hi guys my turbo has finaly give up, I've caught it atvthe right time as just thecwaste gate is stuck on full boost, so my question is: were can I get a hybrid turbo? How much? And what els do I need to get it runnin spot on apart from another map? Also what power will I see after fitting it?
    It for a 2007 170 2.0tdi
    cheers chris
  2. N8
    17,163
    720
    Has anyone done a Hybrid 170?
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,492
    633
    send devonmikeyboy a pm - our local deisel guru!
  4. chris1988brown
    575
    Will do cheers guys
  5. akash_sky1
    akash_sky1 Active Member
    1,181
    Had some problem in my Bora and it gave better torque lower down and made the new turbo even after the remap feel weak below 1800rpm!
    turbodynamics i think in Sheffield also do hybrids. But from what i;ve heard avoid Allard
  6. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    I don`t know of anyone who has made a hybrid PD170 turbo as the few people i know who have heavily tuned a PD170 have just dump the stock turbo and fitted something much bigger like a GTB2260VK and gone for 300 bhp. Saying that the hybrid you hear most people fit have only had a 56mm wheel fitted in the exhaust side so no reason it cannot be done to a PD170 turbo. To guess at a price to modify a new stock turbo £1300-£1500 where as a GTB2260VB can be bought for less then a £1000 but then a new manifold needs to be sorted plus modifications to the down pipe. Companies to email to modify a stock PD170 turbo in England would be Turbo dynamics or CR Turbos which i would go with CR turbos or you can try Finturbo in europe who modified my last turbo and where very good and have a great reputation in the heavy turbo mod group. Other then a turbo and new remap you will need a remap on your DSG box which is the main limiting factor on your car. You can get uprated clutch packs for the dsg box but they are £2000 + to buy before fitting which no doudt JBS has copied buy now or can buy them in from HPA and call them their own. Bosio sale bigger nozzles for your car as well by the way .....
  7. chris1988brown
    575
    Cheers for that mate gonna do some enquirin tomorra now I've got the numbers off the turbo
  8. HIGGINS
    HIGGINS Member
    528
    15
    Ive just had a brand new turbo fitted today as mine sounded like a police siren haha was free under warranty from the garage :D should last me a while im just waiting a few days for it to bed in
  9. devonmikeyboy
    1,245
    You don`t bed in turbos, they either work or brake.
  10. HIGGINS
    HIGGINS Member
    528
    15
    well the garage told me to becareful and give it a couple of days :S ayone else got any thoughts on this?
  11. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    nope, doesnt need to be bedded in, I had 3 so know (and no... they didnt need replacing because I didnt bed in before you say lol)
  12. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Devonboymikey :icon_thumright:
    Dealers :blahblah1:
  13. luke1987
    luke1987 Air Ride is for Ballers!!
    610
    73
    I camt believe ur turbo is fu**ed after 3 years man, isn't that an issue wiv audi?
  14. Phatboyruss1
    Phatboyruss1 Member
    75
    Hi all, my turbo has just been replaced with a hybrid just over a week ago (Remapped '53 2.0 tdi sport) and the boost isn't coming in as early as before and also 5th and 6th gear feel lifeless, will I need a new map on the car?
    One of the problems I had before was the car going into limp mode (overboost limit exceeded), and the problems back... its done it at around 70-80mph but it did it twice last night once at 30 going uphill in traffic and again at 70 (ish). The cars going back to the garage Saturday morning. Has anyone got any ideas what could be the cause?
    Cheers in advance
  15. devonmikeyboy
    1,245
    You have changed your turbo for one that flows more air so yes of coarse it will need to be mapped properly, that is why the car keeps going into limp mode for.
  16. devonmikeyboy
    1,245
    You bed in an engine as there are moving parts that touch each other that need to wear in a smooth surface and harden. A turbo has no moving parts that touch as everything floats on a bed of oil.
  17. navnayyar
    navnayyar Member
    756
  18. navnayyar
    navnayyar Member
    756
    aw and on the bedding in thing. you was told to be careful to allow it to oil up properly :icon_thumright:
  19. alfiejts
    alfiejts Member
    352
    The manual says you should let it idle for two minutes after running it hard before you turn the engine off th let the turbo cool - otherwise the oil boils and it overheats and causes damage to the bearings.
    I'll bet not many people do that... Same with any turbo not just Audi....
    I don't see many other cars sat idling at the motorway services when I'm waiting for mine to cool down for a couple of minutes after three hours blasting down the motorway...
  20. chris1988brown
    575
  21. smudge_don
    smudge_don Active Member
    2,944
    Hmmm, i was deciding whethe to go down the hybrid route for mine or get something bigger
    I'm gonna be taking my car to AMD in Essex soon Chris, i'll let you know what they say about it all
  22. navnayyar
    navnayyar Member
    756
    yep straight plug and play no need to change anything. Its only the internals that are changed like compressor wheels, bearings etc. Ive got a intercooler on now and running 1.8bar happiliy. still need to get around to getting it on a RR ive only held back because I keep modding it. Am thinking uprated injectors but the quiet expensive. but all I know is that a standard s3 cant pull away from me, so am well chuffed and around town driving easy im getting around 36MPG. love it :jump:
  23. devonmikeyboy
    1,245
    @navnayyar I didn`t realise you had a PD170 ? Bosio do uprated injectors PD170 injectors called PPD i can get you. Go on you know you want to really :eyebrows:
  24. navnayyar
    navnayyar Member
    756
    Na mate i have 140pd bkd. Any recomendations for injectors on that? What flow rate?
  25. devonmikeyboy
    1,245
    Only uprated injectors out for the PD140 at the moment are Bosio P1287+ which are +25% flow. I have a spare set of nozzles ready fitted in some injector bodies if your interested.
  26. chris1988brown
    575
    Bloody he'll if ur's has s3 kind of power my 170 should be awsome
    need it all doin this week so gonna get a price on turbo from turbo soloutions who is local and ring local tuner get it sorted n
    hopfully be on the road again next week
    end:)
  27. Phatboyruss1
    Phatboyruss1 Member
    75
    I knew it was silly question.... :laugh:
    Thanks for the response, much appreciated
    Had the codes read and I am getting 2 fault codes come up
    19463 Camshaft position sensor (G40) No signal intermittant
    16683 Boost pressure regulation:Control range not exceeded.
    Guess the cam sensor wouldn't be hepling matters... can it be changed without taking the cambelt off or are the garage trying to add the cambelt swap in?
    The car already has a remap on it (before the turbo change), would a live/rolling map be more beneficial and can anyone recommend a company.
  28. devonmikeyboy
    1,245
    What part of the country do you live ?
  29. Phatboyruss1
    Phatboyruss1 Member
    75
    South Bedfordshire mate
  30. devonmikeyboy
    1,245
    AMD,Jabba and APS are the main ones that spring to mind. Personally i would go to APS or AMD as Jabba tuned diesel cars always seem to smoke a lot.
  31. chris1988brown
    575
    Stage 2 hybrid sorted £890 all in can't wait to get it fit n maped also gettin dsg map at same time let the fun times begin
  32. devonmikeyboy
    1,245
    Thats a good price for a hybrid and £200 cheaper then what Fr+rtuning wanted !
  33. chris1988brown
    575
    Ye mate did what u said n got it through work made a nice differance to the price:) cant wait too see what it's like the power before was more than enough but with the actuator on the turbo goin I thought I may aswell upgrade while I'm at it:) will get it on the rollers probs a weeknor two after the map see what she's makin
  34. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Do hybrids last longer than the oem units on BKD? I'm just going to replace my old turbo @46.000 miles since it sounds like a meat mincer and it was throwing me overboost errors.
