Turbo sound
Coless3 Feb 13, 2013
  1. Coless3
    Coless3 Member
    44
    Hi
    Just wondering if this is normal :-
    sounds like I can really hear the turbo spinning/hissing
    I was driving the car in 4th gear hard and at about 5500-6000 rpm with wot I can hear like a hissing sound so I let off the throttle then can hear the hissing/spinning sound which sounds like it slows down as the revs start to drop?
    Tried it again and I noticed that on my liguid gauge that the bhp stopped gaining at 248bhp as the sound came back?
    I really hope this isn't my turbo ****ed I can not hear the sound in any other gears even with wot.
    Any help please?
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Turbo/boost leak/could be lots of things.
    First thing to do is get a smoke test done.
  3. Coless3
    Coless3 Member
    44
    If it was a boost leak would it not be there all the time ?
  4. 16Klappe
    5,795
    1,184
    Not always, the positive pressure/boost would be pulling it open at full chat where as the rest of the time it stays sealed.
    A cracked exhaust manifold is another option, although not common on OE manifolds.
  5. Coless3
    Coless3 Member
    44
    Would the boost pressure not be the same tho in another gear at wot?
  6. Coless3
    Coless3 Member
    44
    Also I can hear it dump the boost when I let off the throttle but the noise is still there until revs drop
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Check the orange pipe from the turbo to charge pipe...
  8. Coless3
    Coless3 Member
    44
    Any other ideas?
  9. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    The sound you could be hearing could be the turbo blades catching on the inner housing due to knackered bearings... The only explanation I have for the sound being on both wot and over-run... If it was a boost leak it would only be on wot and if the DV is dumping as it should, there will be no air in the system to escape through a leak...
    Ben
  10. Benjiman46
    551
    24
    Are you kidding? They're the more likely to crack than the windscreen man especially after a map lol
  11. Westy
    Westy Well-Known Member
    17,443
    1,103
    Jardo shut the fk up! This forum is here to help people. You're hardly helping by telling the OP outright that the only thing he can do is get a smoke test and that you know what's best! Get off your high horse.
    Yes a smoke test will highlight any leaks but people don't want to run off to the nearest garage every time they get a problem. They post on here, we give them a list of things to go and check. He may be able to spot a split hose visually, replace it, fixed, no smoke test involved.
    Why don't you be a bit more understanding instead of just forcing your opinions on everyone!
  12. Eddie S3
    Eddie S3 Member
    128
    9
    Which hoses do you use if you want to test using a compressor?
    Seen something on Uk-mkvis and they have used a foodcan with an attachment for the compressor and then attached to the MAF
  13. Westy
    17,443
    1,103
    That method is usually only used for testing between the charge pipe to the TB and is normally for FMIC leak testing. This won't highlight any of the issues with hoses connected to the inlet manifold, TIP, N75 etc.
  14. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Any VCDS logs or fault codes? It'd be interesting to see if it's making (or exceeding) requested boost, and indeed what requested boost is.
    Also what model/spec is that car?
  15. Prawn
    11,444
    3,339
    oh dear, looks like this thread has been moderated after another attack from Jardzilla.....
    Benjiman46 likes this.
  16. s3dave
    10,110
    736
    I just thought Westy was hearing voices.... ;)
