Turbo rip off?
WISHY Apr 29, 2009
  1. WISHY
    WISHY New Member
    13
    My 2005 A3 2.0tdi was towed to the garage this morning as it wouldn't start and the oil pressure warning light came on. The end result was the garage says it needs a new turbo which is going to cost about £1500!! ouch
    Is this the going rate for a new turbo or am i being ripped off?
    Ps the car has a Superchips Bluefin and has done 65K miles. The garage is the local VW dealership as the Audi dealership is too far away for the breakdown recovery.
  2. Lee_R
    Lee_R Active Member
    2,499
    12
    Sounds pricey, most people i've heard have had a recon fitted for around £700-800
    Shop about!
  3. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    there's one on ebay for 350 check Audi a3 turbo ....12 month guarantee
  4. APL TDi
    APL TDi Member
    289
    1500 quid is a bit steep mate. You should be looking at a grad max if done at audi.
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    out of interest, did you drive home ok & it was only when you when to start it again that you had the problem, not when driving it that it packed in? Was there no warning signs. Does a blown turbo stop a car from starting?
  6. kettle
    kettle Member
    176
    that is steep!
    the car would still work, a blown turbo usually causes smoke out the exhaust.
  7. frenchy2475
    frenchy2475 Tetbury Audi Parts Man
    263
    Turbo with gaskets are 1253.24 inc vat just for the parts alone, plus labour! so 1500 is about right at a main dealer.
  8. APL TDi
    APL TDi Member
    289
    Seriously?
    I stand corrected:salute:
  9. WISHY
    WISHY New Member
    13
    Thanks for the replies folks....Khufu...the car was working the day before no warning signs....got in the car the following morning and it wouldn't turn over and the oil pressure warning light came on.....eventually managed to get the car towed to nearest garage...no PAS meant it was a nightmare to recover. The VW main dealer garage says that the car will only start with the turbo disconnected???
    The internet suggested that blown turbos are not uncommon in cars of a similar age or mileage, its just the way the fault appeared that concerns me....ie no white smoke, being unable to start car.....but my service records show new oil/turbo seals have been fitted, plus i have noticed oil leaks in the past.....me thinks this has help increasing wear in the turbo???
    I appreciate DIY/refurbed turbos are cheaper but I'm no mechanic and getting an immobile car to another garage would be difficult.
    All because i considered changing my car this week....she obviously dosen't want to go....ANYWHERE :laugh:
  10. frenchy2475
    263
    Yeah, the turbo isnt on exchange basis hence the high price.
  11. kettle
    kettle Member
    176
  12. kaz219
    kaz219 Active Member
    1,808
    Why wont the engine turn over if the turbo has blown ?
    Mine does and the turbo is popped ?
    Doesnt that mean the engine has seized due to low oil/low oil pressure or has the oil pressure sensor stopped the engine from starting?
  13. Khufu
    5,704
    31
    im guessing the turbo has seized after he got home due to it still being hot but no oil getting pumped round it. With it being seized there will be little or no gas flow - like sticking a potato in the exhaust!
  14. mhill
    mhill Member
    323
    Sounds like the perfect excuse to go BIG TURBO, go on you know you want too!
  15. kaz219
    1,808
    But would it not still turn over but not start?
  16. WISHY
    WISHY New Member
    13
    Big Turbo...LOL no chance...Bluefin is enough otherwise my driving licence in danger!!
    Kaz.....the engine would not turnover
  17. Khufu
    5,704
    31
    Im not sure, depends if the air can be compressed enough between the chamber & the turbo. If no air is getting pumped out, none will be getting sucked in?
  18. Khufu
    5,704
    31
    Ah, theres the answer :salute:
  19. kaz219
    1,808
    That makes sense - i really need to get my turbo off to see whats happened.
    It turns over but i havent started it incase a bearing or something flys into the engine.
    Thought I might have got lucky with the urbo not being blown as it starts but no such luck :(
    Thanks for clearing it up
  20. kaz219
    1,808
    BTW mate - my turbo was £350 new (my garage got it me) and not got a fitting price but my garage are always cheaper than the rest (my dads mates so they look afer me)
  21. WISHY
    WISHY New Member
    13
    Kaz....lucky you.....I didn't have that option...the local garage decided they couldn't fix it so suggested a main dealer...the only main dealer within the 10mile limit of the breakdown was the VW garage....... today I got a quote from the local Audi dealer 25miles away and it was again about £1500.
    If you live in the Country like me your options are limited and more expensive....but the roads are quieter and there's fewer speed cameras!!!
