turbo removal help please. audi s3 8l.
JonBoi25 Sep 4, 2011
  1. JonBoi25
    JonBoi25 Member
    236
    Hi there,
    Many of you will of commented on my post about my engine issues.
    Im in the process of taking off the turbo. Im nearly at the point of lifting the turbo out but I cant see an easy way of removing the turbo exit to downpipe 16mm nuts any guidance\tips much appreciated.
    Thanks . Jon
  2. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,753
    187
    Hi Jon did you try what Dave suggested and run it for a bit.
  3. JonBoi25
    JonBoi25 Member
    236
    Hi bud , I ran it for a little while but it didnt seem to clear.
    The symptoms indicate that its issues with the turbo. For oil to have got in the exhaust exit of the turbo system it will have had to leak past the main turbo oil seals. My view on it is if the seals been pressurised so it leaks then the seal wont sit snug in its original position correctly again and if it does it still wont be 100%. I think for piece of mind I want to get the turbo off and renew damaged breathers etc while im at it. Got contacts at work with turbo technics so hopefully wont cost loads for full recon and then ill know its all pukka and the system will be fingers crossed totally sound :) . Got those nuts off now trying to remote oil andcoolant deeds etc ? :) many thanks
