Turbo question K04-022
oversteer Aug 16, 2007
  1. oversteer
    oversteer New Member
    23
    Hi everyone,
    I just had my turbo replaced on my 01 S3. I managed to find a K04-022 the shop fitted it for me and retuned the old unit to me... Funny thing is it looked slightly different? The model number on it said K04-023... and when I do a search on the net I found that my car came out with the K04-022?
    So these are both BW KKK turbo's.... however! With my new one fitted my car feels stronger and when I liftoff below 3000rpm i hear a flutter.
    Anything to be worried about?
  2. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    The 23's have a silencer I think?
    Do you have a larger output on the shell portion of the tubo, looks like a big can?
    No difference though, between silenced and unsilenced (except the obvious) but the flutter would worry me...
  3. oversteer
    23
    Big can... are you refering to the wastegate?
    The 022 looks bigger in comparison... but like I said the flutter is only when I drive slow...
    I spoke to my local tuner (nxgen) and they said they normalyhave the same affect when they remove a stock turbo and fit a bigger aftermarket on to a wrx...
  4. Dave_Bayern
    1,913
    The wastgate is internal on the K04, the wastgate actuator is not, but thats not big, or can shaped.
    This is on the output of the turbo, the hot side if you will, and whereas the old K04 will have been a straight pipe coming out, now it will have an extra thick piece just before it joins to the intercooler piping.
    When you say flutter, is it flutter, or like wastgate chatter, which can point to your DV/N75 being dodgy.
  5. oversteer
    23
    Cant recall seeing any extra pipe on the hot side...
    ...the fl;utter sounds like the track cars or rally cars even.
    ive been told it could be the air banging against the empeller?
  6. Dave_Bayern
    1,913
    This is a K03s with silencer but you get the idea:
    K04 without silencer:
  7. Bellic
    Bellic Member
    265
    bit off topic by how much does it silence it with that unit
  8. Dave_Bayern
    1,913
    I can only do a comparison with the K03 based turbocharger, silenced and unsilenced, but quite a lot, you dont hear the spool up sound, in fact on my car, you only hear air rushing in and around the Forge TIP, no spool sound as I was used to before.
  9. Bellic
    Bellic Member
    265
    so the spooling sound is heard on pressure side only
  10. oversteer
    23
    Ok my turbo 022 (on my car now) looks exactly like the one you have in the 2nd pic... I have no silencer... actualy ive never seen anythiing like that...
    i do hear the spool up and dump...
    What are the differences - power wise....?
  11. Dave_Bayern
    1,913
    Silenced and unsilenced have NO difference in power or flow.
    Your old turbo was knackered then obviously? which is why you got it replaced?
    The 22 and 23 were just different year turbos but no actual power difference.
    The flutter noise is weird, its definately a flutter and not like a rally car chatter then?
  12. oversteer
    23
    For the record,
    Audi S3 Quattro 2001 154kw
    Forge DV
    Samco hosekit
    Acuamist 2d
    Revo sps3
    decat downpipe... 63mm zorst
    New K04-022 turbo
    New oe Clutch stock
    BMC cone filter
    New coilpacks OE 115R
    New oe aux water pump
  13. oversteer
    23
    I really wish I could be more clear...sorry...
  14. oversteer
    23
    The old turbo broke... the shaft snapped and cracked the exhaust housing... bending the empellers on either side....
  15. Prawn
    11,370
    3,234
    another difference between your setup and mine...... ive got an unsilenced ko3S to go on......
    couple that with my exhaust, and it might end up quite noisey :S
  16. Bellic
    Bellic Member
    265
    the k03s on mine is unsilenced one spool sounds nice , not mapped yet though
