Turbo question if i may.....
tspar Dec 17, 2009
  1. tspar
    tspar New Member
    24
    I have heard that after a long drive that its best to leave the engine running for a couple of minutes after stopping before tuning the engine off to avoid any potential heat damage to the engine. Is this "Good practice" in the turbo world?
    If this is the case then what would everyone consider to be the minimum amount of miles to be done before following this practice?
    Any thoughts as ever appreciated :thumbsup:
    Tim
  2. N8
    17,163
    720
    That is neccessary with big turbos yeh. But just let the turbo warm up for 10 mins and cool down for 10 mins at the end of your journey, this will prelong the life of the turbo.
  3. DeckedS3
    DeckedS3 Well-Known Member
    882
    304
    Not really something I do... Maybe after a hard drive and turbo/engine hasn't had a chance to return to normal running temp.
    But I think leaving the engine running with no air passing through could do more harm than good IMO.
  4. tku
    tku Member
    630
    I thought you only do that with evo's and subaru's as their turbo's are huge.
  5. tku
    tku Member
    630
    Thus the majority of them have turbo timers.
  6. Haglos
    Haglos jabba mapped
    247
    not so much do it every time but after a spirited drive i always alloy 3-5 mins of cooling down and i always warm the turbo up
  7. Chris128
    Chris128 Member
    79
    I'm sure I read in the handbook somewhere that it says not to leave the car standing still with the engine running if you can avoid it... maybe that was just for fuel economy or something I dunno, I'll try and find the exact words..
  8. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    It's only necessary after a hard drive not a long drive. It allows the oil to spread around the turbo otherwise the next time you start up it's starting without any lubrication.
    IIRC that is!
  9. Dandle
    Dandle Member
    852
    If you just do the last few miles off boost then that is fine, just turn it off. If your coming off the motorway into a service station for instance or been ragging the car hard its advisable to let the engine tick over for a minute or two to let the turbo come down in temp while it still has the oil circulating and cooling it. Same when you start driving the car dont drive it hard until the oil is up to temp as its not providing maximum protection for the engine/turbo.
