Turbo pressure noise under acceleration - help me tell dealer what to look for!
chiefb Dec 21, 2007
  1. chiefb
    chiefb New Member
    Hello all,
    I've just received my 2002 S3 (225bhp) back from the body repair shop. It needed a new passenger side front wing and headling after a dustcart decided to scrape it down one side whilst it was parked...
    Anyway - the car is now making a new noise. It can only be heard when accelerating and working the turbo, and initially sounds like a raspy noise coming from quite low down behind the passenger footwell or glovebox.
    If you then release the accelerator, you get a whoosh / fizz noise, like the pressure is being dumped.
    I had initially suspected the Diverter Valve problem as documented here:
    --- sorry can't post url's yet --- thread number: 19986
    but having taken it to local mechanic and then Audi dealership, they don't reckon it is this, given where the noise seems to originate from (although I don't think they've done any proper diagnosis).
    I'd appreciate any input you may have for me, so I can re-brief a mechanic for what to look for. So far I have:
    - check for split pipes on/around intercooler
    - check intercooler itself (I've heard of cases where seals can crack?)
    - exhaust manifold/gasket from turbo
    What else am I missing?
    I'm obviously suspicious that something was damaged during the recent repair work, but until I find the cause it's difficult to prove. This post looked promising baring in mind I had the wing changed, but it would seem that this isn't something that could affect a standard un-modded car ?
    --- sorry can't post url's yet --- thread number: 12243
    sorry for the essay! and thanks in advance
  2. audi-tech
    audi-tech New Member
    15
    Theirs an orange pipe behind the turbo that sometimes spits.. but that would not relate to the area you are hearing it from.. Have you checked both intercollers?
  3. S POT
    S POT Member
    30
    Mine has always given a whoosh / fizz noise as you have discribed when you let off the throttle or on gearchanges? Is this not normal with S3`s then?
  4. chiefb
    chiefb New Member
    Not to the extent that I'm now hearing, and it's noticable when the turbo is spinning up as well - almost like a raspy exhaust note..
    I'm going to be vigorously checking all the pipes to and from each intercooler over xmas, so I'll let you know how I go..
  5. james_S3
    james_S3 New Member
    17
    i have exactly the same problem with my S3. Its standard apart from forge DV. I have posted a thread but didnt have many suggestions apart from take it to a garage!!!! I have checked everything now (i think!!) and its driving me crazy!!! also seems like its lost power :sadlike:
    really does sound like its coming from around the air box area. Does anyone know if the N249 valve that controls the DV could be dumping the boost back into the TIP? Although the car does peak at 0.8bar and does not drop off!
  6. chiefb
    chiefb New Member
    Well - it's definately not the DV. Mine was changed today and noise is still there.
    Going to get the garage to replace the intercooler pipes and clips next. Really hoping I haven't got a puncture in the intercooler!
  7. simch
    simch Active Member
    2,028
    What does vagcom say?
  8. jamieface
    jamieface the only S3 in the villiage
    196
    this all aounds very familliar. my car 2001 S3 is doing the same and it seems like it lost power ?? is the noise like a sucking air kinda sound ??? or a whooshing noise from behind the glove box ?? not a good description i know but hey !!!
  9. chiefb
    chiefb New Member
    Yep that is exactly it.
    It's tricky to describe - as without hearing it, most people just think it is the normal operation of the turbo - but I know different because I've owned the car from new - and the noise has only appeared after the recent repairs to front wing..
  10. S POT
    S POT Member
    30
    So should there be no noise when the throttle is released or on gearchanges? Have'nt had my car long and it has always made a loud whoosing sound when changing gears etc. My mum had a 2003 S3 and cant remember hers making any noise :blink: Feels a bit flat aswell!
  11. madvw
    madvw Active Member
    2,489
    as simch says, you're going to need a fully registered version of vag-com to get to the bottom of this one. You need to log requested Vs. actual boost to see if you have a boost leak.
    Seems a bit fishy though that you had an accident in the location where there's a SMIC, and now you have weird noises when boosting.
  12. JB_A3_Turbo
    JB_A3_Turbo Member
    98
    I've had this kind of noise on my 1.8T. DV was replaced but no different. Had it remapped a year ago with revo and replaced the DV with a forge eliminator valve. Noise is still there though. I'm fairly sure that this is normal-someone on here explained comprehensively ages ago. My car doesn't feel under powered at all, nice and responsive (probably 185-190bhp) and is as fast as I'd expect it to be for the power..
  13. Backdraft Motorsport
    Backdraft Motorsport 1.8T & 2.0TFSi Specialists Site Sponsor
    212
    73
    Dont waist time and money fiddling around without doing a pressure check. If you are in the Milton Keynes area, pop in and we will do a pressure test for you. Otherwise ask a good local independant to carry out a test for you. It's the most cost effective way of locating your problem.
    Best Regards
    Mark
    01908 821216
  14. james_S3
    james_S3 New Member
    17
    i have pressure checked the whole system from the turbo to the inlet manifold!!! Still no luck. And i have got 0.8bar of boost which does not drop off. Really does feel underpowered.
    Just a thought but could the n245 valve (which regulates the vacume to the DV) on top of the rocker cover be at fault causing the DV valve to leak pressure into the TIP? But then sureley my boost would drop??
  15. danotto
    danotto VAG HUNTER
    1,090
    i know this sounds daft but are you sure that the turbo inyake pipe isnt split anywhere allowing air to be sucked into the pipe from the engine bay rather than just the air filter?
    Mine also has a slight whoosh but im sure its normal.
  16. natedogg1983
    natedogg1983 New Member
    s3 2001. just got the car and few days after driving it for about a week i have got a new noise. you cant hear it when driving steady, but when you give it some you can hear the turbo spooling up, then a louder noise when it really goes. It isnt the standard noise because it didnt use to sound like that.
    it still goes ok but dont think its right. couldnt keep up with civic type-r today..... not what i wanted .
    worried.
  17. ianysm
    ianysm Active Member
    1,002
    Definately sounds like a leaking pipe somewhere. I'd check around the area they repaired. Hope its not a faulty intercooler, but could be damaged in the accident?
  18. Biggied
    Biggied They called him mellow yellow.
    198
    If its only happened since the wing repair I'd have the cold air feed that pokes through the n/s/f inner wing looked at, its an oval shape pipe that feeds into the end of the airbox. When this isn't sitting right it can make a slight sucking noise as you've described or a deeper induction noise (like an cone filter/modded airbox). The afore mentioned recirculating valve releases its pressure into the intake pipe so the more intake/induction noise you can hear the more valve noise you hear, this would explain the noises during accelaraiton and when lifting off.
    An incorrecty fitted/sealed air box top section can cause the same noises also.
    If it isn't infact a boost leak you have this is the area I'd be looking at!!
    Cheers Ewan.
  19. natedogg1983
    put boost gauge on today. to check things out..
    it peaks at about 19psi around 4000 rpm. after that it dies off, and by 6000rpm only getting 10psi. is this usual for am 210bhp S3.
  20. subby
    subby Member
    126
    hm...
    Ive got this, but i know why lol. It got noticable when i put a pipercross panel filter in, and even more so now with a cone. I always thought it was normal, someone on here explained it was normal a while back i think.
    mine only does it under low boost, on full throttle/full boost it goes away and off i go :ninja:
  21. S3KO4
    S3KO4 Member
    850
    19psi from a 210 with no map is a bit optimistic. unless it has been mapped before you. it is normal for boost to tail off but not sure on the standard map!
  22. natedogg1983
    i think it might be my dump valve?? can you bypass it somehow
  23. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    No you can't bypass the dump valve, it is there for an extremely specific reason! I'll explain below.
    A possibility, but unlikely. You would experience boost drop since the whole point of the N249 valve is to regulate boost. It will be used if the MAP sensor tell the ECU there is more boost than requested, and is also used to limit power if the traction control deems it necessary. Lots of info about the N249 and vac chamber on this post: http://www.audi-sport.net/vb/showthread.php?t=84344
    If you believe this to be the problem, you can bypass it. This is the link to my 'How To' thread: http://www.audi-sport.net/vb/showthread.php?t=84402
    What you all seem to be lacking here is knowledge of the point of the Dump/Dirverter valve on an Audi 1.8T engine. The Forge 007p and standard Audi DV are both DIRVERTER valves.
    DV Theory: When you let your foot off the throttle (and the throttle body's butterfly closes) the air being pumped out of the turbo at pressure suddenly has nowhere to go.
    Without a dump valve, this air would start pressurise the pipework and eventually prevent the turbo spinning (called compressor surge or turbine stall).
    An atmospheric dump valve vents this air into the atmosphere (obviously), making an audible Ptush noise (think Subaru!).
    Our 1.8T engines have a diverter valve. Similar principle, however the air doesn't get released, it gets put back into the inbound air flow to the turbo. This rush of pressuried air helps prevent turbo lag when changing to the next gear. However, not all of it gets recycled through the system, especially if changing gear slowly. In this case, some of the air goes back out through the air filter (since the DV only puts the air in not much after it). This is the noise you will be hearing when changing gear and/or letting off the throttle.
    A cone filter, or incorrectly closed/cold air feed pipe removed air box will make this noise MUCH more audible as the air escapes out of the filter.
    It will be louder if you change gear when the turbo is at full spool, quieter if you are only doing 1500 rpm. Obviously the more the turbo is working, the more air moved, more pressure, bigger release noise. If tanning it/at full boost, you will be changing gear quicker (normally) and more air will be reused.
    Have a look here for more info http://en.wikipedia.org/wiki/Blowoff_valve
    This is absolutly spot on, and exactly where I would start.
    Sorry for the long post - but hopefully it'll be useful. :)
  24. Welly
    10,696
    129
    Expect the standard map to drop the boost off. If you want a bit more, might be worth thinking about a different N75 valve (more specifically the N75J). Can cause limp mode due to overboost in some S3s, its a bit hit and miss. But if you want to get a bit more boost/better performance for £50 from Audi, it's worth a punt IMO. I've got one :).
  25. Welly
    10,696
    129
    Who's to say that Civic Type R wasn't messed about with? They're somwhere handy to 200 BHP standard, with no 4WD mechanical lag and lighter than an S3 in the first place....
  26. MIKE GTR
    MIKE GTR Member
    366
    ^^^^ the 3 most sensible and understated posts that i've so far read on here
  27. natedogg1983
    put standard one on but still noise.
    diy pressure test next
  28. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Had this same problem today...
    It was the 2 pipes that come off the hard top boost pipe ... one goes to the DV one goes the the N75 valve...
    Where they come off the boost pipe they take a sharp turn... check they arent split. mine was and by christ was the turbo loud !
    They are not too cheap from audi... mine are now silicone... should work well.
    Hope my finding help you too.
  29. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Some really informative stuff in this thread, especially from Welly.
    Reading all this has got me thinking about my 2003 S3, which I bought in July this year. It has a stage 1 remap from APS in Brackley & a Forge 007P fitted. Air filter is standard.
    It's the 1st turbo car I've owned, so I'm not familiar with a lot of the technical stuff but...
    When I am accelerating I can hear & feel the turbo spooling up. After around 4k rpm when accelerating I start to get a different noise that is almost like sucking the last bit of a frothy milkshake up through a straw (know what I mean?). Acceleration still pulls well with no ovious issues. Is this noise OK?
    The car's done this since I bought it & I've had it Vagcom'd with no issues.
  30. Welly
    10,696
    129
    Yeah, if it's always done it with no side effects then I'm sure it's fine. All cars make different noises depending on the hardware that's attached to it.
    Its really difficult to describe noises, I well know, but at 4K your turbo will be at full spool flowing a little under 200 grams per second of air. That's a lot of air! I expect the noise you describe is the turbo pulling it through the air box/filter.
  31. Simon/s3
    Simon/s3 New Member
    23
    Did you ever get to the bottom of this mate I have the same problems with my 2001 s3 at the moment :/ thanks
  32. Simon/s3
    Simon/s3 New Member
    23
    Did you ever get to the bottom of this pal I have the same problems
  33. <tuffty/>
    21,577
    4,049
    Whoa!!... the quoted replies are nearly ten years old dude...
    I would suggest you start a new thread explaining your problem and any fault codes or other diagnostics you have done...
  34. Simon/s3
    Simon/s3 New Member
    23
    OK mate il give that a try
  35. Simon/s3
    Simon/s3 New Member
    23
    How do you start a new thread?
  36. <tuffty/>
    21,577
    4,049
    I have to say thats the first time I've been asked lol
    Go to the main 8L section and there should be a button near the top with 'Post New Thread'.... enter a title and explain your issue stating model/year/engine code (if known) and go from there
  37. Simon/s3
    Simon/s3 New Member
    23
    Haha cheers it's cus my phone doesn't display it all properly now I've found the section it's obvious
