Turbo possibilities
chrisa4quat Oct 29, 2012
  1. chrisa4quat
    chrisa4quat Active Member
    970
    I am looking at the turbo upgrade on 2.0t dtm. I know ko4 is usual route. What other turbos are available? Any direct swap? I don't fancy having to fabricate a down pipe etc for the ko4. Thanks
  2. solaris
    solaris Member
    416
    17
  3. chrisa4quat
    970
    Is that good for 330-350?
  4. solaris
    solaris Member
    416
    17
    Yes, with supporting mods it should be
  5. chrisa4quat
    970
    OUCH Just seen the price. Maybe I should stick with the ko4 and have to do a little more work
  6. g12
    g12 Member
    43
    So basically you could get the internals from a k04 and put them into a k03 housing? Im assuming the k03 housing will need machining so that it fits in? If its that simple - its 4 bolts and the internals are out (with the turbo/manifold off) ......why go the whole way of swapping the whole turbo unit? and piping up?
  7. solaris
    solaris Member
    416
    17
    Think there is some serious machining involved and the internal from the KO-R are not std ko4 items, but by all means do give it a go and feedback.
  8. g12
    g12 Member
    43
    Most likely will be alot of machining involved! The turbo I brought off you - I swapped the cartridge out for mine and it works fine..... Just thinking I should of swapped it for a K04 cartridge at the time.
    If I get hold of a K04 I'll see if its do'able.
  9. Craig Cull
    Craig Cull Well-Known Member
    2,374
    1,281
    still got the k04 if your interested mate? Was gonna save it but the conversions easily a year or 2 away. £250
